Best CAM for Echostar AD3000IP
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 24-04-2005   #1
PWH
My System: Loads of stuff
Smile Best CAM for Echostar AD3000IP
Hi all, I have just got an Echostar AD3000IP with just a S*ca cam.
Which is the best cam to use with one of these sets? I particularly want Viacess2 which should be straightforward IRDETO and CONAX.
By best I mean no freezes, update files readily available easy to update widest range of usability I have been told Matrix revolution Do you agree what is the difference with a reloaded? How about a Joker CAM? What else?
PWH is offline   Reply With Quote
Old 05-05-2005   #2
Hi M8,
I have the echostar 3000 like yours, and i can say without any doubt that any cam will run in it. i have several different ones no problems ever. wurzel.
wurzel is offline   Reply With Quote
Old 12-05-2005   #3
misterminibus's Avatar
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought.
Cams
I have a dragon and a mrev and have to say I find the mrev just that bit quicker
with a AD3000ip but both clear and no freezing so take your pick
misterminibus is offline   Reply With Quote
Old 14-05-2005   #4
PWH
I ended up with a matrix reloaded which works OK but I can't get any card to work with it only the internal emulator.
ad3000ip, cam, echostar
Similar Threads
any hope for ma useless Irdeto CAM yet sat_freak Irdeto system 7 10-05-2006 04:32 PM
diablo cam wolfav Cams and decoders General 0 08-05-2006 04:28 PM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
Matrix Reloaded CAM Pandora Matrix Reloaded, Revolutions and CAS interface 11 04-02-2004 07:41 PM
Axas Cam and Dreamload jderby Cams and decoders General 2 28-08-2003 05:52 PM
