Humax 5400z receiverCAMs, built-in CAMs, Common-Interface CAMs... | |
| Member Join Date: 10-09-2003
I have a Humax 5400z receiver HoTplugged v5.3 i got funcard 4 Euro 1-chip version: NEC v2.1 can you Please help and tell me how to get Multivision and XXL with hotbird coming up try v do i need a cam or key code | ||
| Regular Member Join Date: 23-10-2004 Location: Pakistan
Hi Dear alee8 Good Morning Its so easy, just update the latest Toh 3.3 Hot 5.5 using null modem cable then use the Sammy+Hummy loader (sellect any encrypted channel) put a Fun Card in the embeded cam and update the latest keybin, on getting the channel operational press RCL then "0". You are done mate!. Good luck! Regards Mumtaz Rizvi | ||
| 5400z, humax, receiver |
Similar Threads | ||||
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| Lists of Software upgrade sites | jo_lb2002 | Receiver software, international Section | 17 | 23-11-2004 08:05 PM |
| Humax 5100 or Humax 5400z | internetbasic2000 | Digital systems | 9 | 28-05-2004 03:04 PM |
| Humax 5400z Reference Satellite | wolsty | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 12 | 25-02-2004 11:54 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
