Blue Zeta cam
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 28-06-2005   #1
tall_paul's Avatar
My System: Force 1122s Cas 2+ addon MR, Aston, blue zeta
Blue Zeta cam
Hi
I have just bought a blue zeta cam full-x 1,2 and put it into spare slot of my Force 1122s but nothing happens? I have gone into the menu and it does not appear in the access control. I have taken it out replaced both my MR and Aston cam which do come up in the menu but still no response. I have also looked int the package menu and it says Norden, Canal Digital, Conax is this correct?
tall_paul is offline   Reply With Quote
Old 28-06-2005   #2
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
It should show in the CI menu as neotion I believe.
Jimbo
jimbo is offline   Reply With Quote
Old 28-06-2005   #3
tall_paul's Avatar
What do I do when it doesn't show what it is suppose to?
Old 28-06-2005   #4
sonic1's Avatar
My System: Dreambox 7020si,SIF 1.9.4- Dreambox 800HD Nabilo BH 0.12 Netgear adsl router, 98cm Funkee on Diseqc motor, Maintaining Hummy 5400 for the old man!
Can you try it in another or a mates stb?
If not do you have a cas2 or 3 ?
sonic1 is offline   Reply With Quote
Old 29-06-2005   #5
jimbo's Avatar
Also any possibility of speaking to your supplier? I purchased one ages ago to play with and it worked fine in my old Echostar 3000. Tried it tonight and it's ok in the Manhattan.
Jimbo
Old 29-06-2005   #6
tall_paul's Avatar
Hi
Have spoken to supplier and he suggests same. Try it another reciever, if it does not work I can send it back for a new one. Yes I have cas2 with addon. What do I do with the cas2?? Cheers.
Old 29-06-2005   #7
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
You need to use the J-Card that comes with the CAS2.
Place the J-Card in the cam first, insert the cam into the CAS, and the J-Card cable into the external connector of the CAS.
'Joker Connected' (same as Zeta Cam) shows in the CAS Menu. (Make sure the J-Card is inserted correctly in the CAM).
Follow instructions in the Menu (i.e. open your file , select and program).
Llew is offline   Reply With Quote
Old 29-06-2005   #8
tall_paul's Avatar
Cheers Llew
Only one problem, I think I must have got stiffed. I didn't get J-Card with my CAS2. Can I not just put the cam in the cas2? Does this not achieve the same result? Do I also read you correctly in that the blue zeta cam is the same as a joker cam? Many Thanks.
Old 29-06-2005   #9
jimbo's Avatar
I think the CAS2 is sold on it's own (cheaper) or as part of a deluxe pack (dearer) with jtag and dummy board. Maybe you have the first one I mentioned. I must admit I don't like those jtag thingys because with the CAS1 it was suggested 'wobbling' it in the cam to get a connection. So I wobbled it and blew a diode. Were Duolabs interested, yeah right.
Anyway apart from all that you shouldn't need to program the cam if it's been programmed by your supplier. Full x is for life I believe. Try it in another box.
Jimbo
Old 29-06-2005   #10
sonic1's Avatar
Hi tall_paul!
Yes blue zeta is a joker or merlin or blue ice ect.
You will need the j-tag to programme it if it is the cam that is at fault.
you will then need the cas2 file followed by Kamilz 112c fun5 file.
Both are readily available should you need them.
This what the j-tag should look like!
Old 08-07-2005   #11
tall_paul's Avatar
Hi sonic1
Cam not faulty as I have tried it in a friends receiver and it works. Got it back today and the bloody thing still doesn't in my Force 1122s. Anybody got any idea's?
Originally Posted by sonic1
Hi tall_paul!
blue, cam, zeta
Similar Threads
any hope for ma useless Irdeto CAM yet sat_freak Irdeto system 7 10-05-2006 04:32 PM
diablo cam wolfav Cams and decoders General 0 08-05-2006 04:28 PM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
ice crypt blue CAM khatm Cams and decoders General 4 30-08-2003 12:15 AM
Axas Cam and Dreamload jderby Cams and decoders General 2 28-08-2003 05:52 PM
