Viaccess Redcam Initializing Frequently.CAMs, built-in CAMs, Common-Interface CAMs... | |
| Member Join Date: 13-04-2003
| I have a Viaccess Redcam with a funcard in a Praxis Digislim 9900CI receiver. The problem that I am having is that the cam initializes every often, sometimes even every minute. I have the latest viaccess software in the cam. Furthermore, the cam can get really hot after sometime but the problem above occurs even when the cam is cold. I would appreciate some advise. Thanks. | ||
| Regular Member Join Date: 01-06-1999 Location: moon
| I have similar problem but not so bad. Red CAM initialize ever few hours. First I thought was card but now I think maybe fault in CAM. I will try another CI slot also another decoder to see if make any difference. CAM only pretty new so maybe I have to send back. theslydog | ||
| Life's short, go hard, rest when youre dead. | |||
| I would like to say 'they all do that' as one of my customers has official Smart card for RTV and Red Cam, however it is actually down to the receiver and the voltages put out to the PCMCIA slot The only real solution is to put a fan in the cabinet or leave the receiver open completely (or change the receiver) | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| Channel Hopper Thanks for advice. Actually because u say try CAM in another Rx - I put Red CAM in another Hummy I got and it no problem. Both Hummies are 5400's not Z models one is 1998 model other is 2001. 1998 model so far no problem. Bit strange - Aston SECA CAM work fine in both. So must be fine tolerence of heat and/or voltage. tsd | ||
| frequently, initializing, redcam, viaccess |
Similar Threads | ||||
| R.R. Satellite Communications Ltd with Viaccess | net1 | Daily Satellite and Broadcast industry News | 2 | 13-03-2009 01:56 AM |
| Eutelsat satellite WC full channel coverage list | Analoguesat | Jimbo's Football and Sport | 0 | 07-06-2006 11:27 PM |
| HRT switches to Viaccess 2 | net1 | Viaccess | 1 | 14-12-2003 09:08 PM |
| Viaccess 1 card read/write? | bg321 | Viaccess | 4 | 14-09-2003 03:34 PM |
| Nokia 9600S & Viaccess RedCam V481? | Ix | Viaccess | 5 | 27-01-2002 11:45 AM |
