Cryptoworks for Aston 1.03
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 25-02-2006   #1
My System: Motorised also one fixed with 19/13d arm and one fixed on28d E, os windows 2000
Hi All
Does anybody know where I can download Cryptoworks cam file to flash Aston v1.03???
henno is offline   Reply With Quote
Old 25-02-2006   #2
Lefdata.
v1.12 and v1.14 work, v1.15 will destroy your cam.
But it's a waste of time, there is nothing you can do with the v1.12 or v1.14 versions.
Burnham Beech is offline   Reply With Quote
Old 28-02-2006   #3
But what about Aston V1.03 can this be flashed to Cryptoworks??
Old 28-02-2006   #4
Yes - Aston 103 will go to Cryptoworks v1.12 and v1.14
But these don't do anything with any known card, as I said first time.
Old 23-03-2006   #5
Can Aston v1.03 be flashed to Nagravision??
Old 23-03-2006   #6
Yes, but there is nothing interesting you can do with it now.
About a year ago there were funcard files that could clear the old nagra1 channels with a converted aston103 cam. The providers kept increasing the speed of the encryption until eventually the funcard files stopped working.
Nearly everything now is in nagra2 and that is beyond the cability of the SCM nagra cam.
Old 13-09-2008   #7
My System: PC ONLY
Hi I have just bought a second hand Aston CAM v1.03 and cannot get it to work in Sony crt TV. Not sure if TV not working it properly or whether I need to upgrade to NAGRAVISION. TV recognises existing card though I am unable to access set up option. Setanta card does not work with it
Consequently, I believe version of the card is the problem. Does anyone know how I can upgrade the CAM to Nagravision?
MARK2000 is offline   Reply With Quote
Old 13-09-2008   #8
Site administrator
Analoguesat's Avatar
TUTV uses seca 2 so theres no point upgrading it to nagravision!
Analogue forever!
Analoguesat is online now   Reply With Quote
The Following User Says Thank You to Analoguesat For This Useful Post:
MARK2000 (13-09-2008)
Old 13-09-2008   #9
My System: PC ONLY
Setanta card has nagravision all over it and assumed I needed Nagravision CAM? Aston CAM is seca marked so are you saying my card should work with it? Or do I need an upgrade?
It maybe connection with TV that is the problem?
Old 13-09-2008   #10
Site administrator
Well blow me down - Setanta swapped from Seca to Nagra according to wikipedia.
So you do need a nagra cam or one of the new ones that emulate it.
Analogue forever!
Old 13-09-2008   #11
My System: PC ONLY
Yes I believe that to be the case but elsewhere I have been told Aston v1.05 works? Is there a way to upgrade my card or is hassle not worth it? I.E. Should I just buy a Nagra CAM?
Old 13-09-2008   #12
Site administrator
If you can find a setanta cam buy one of those. It will be guaranteed to work. An Aston 1.05 is seca - Ive got one myself lying around somewhere from years ago.
You do realise Setanta via DTT is the expensive way of watching Sultana dont you? Only one channel when the same money gets you all of them via satellite.
Analogue forever!
Old 13-09-2008   #13
My System: PC ONLY
Thanks but have TOPUP TV until HD more mainstream and will then update box and TV!
If there is a way to update ASTON CAM then appreciate advice. Alternatively, you might send me your spare v1.05 card for me to try?
103, aston, cryptoworks
Similar Threads
embeded cryptoworks telly2 Conax, Cryptoworks, Nagravision, NDS and Others 5 04-03-2004 11:09 AM
Watch Cryptoworks channels with SkyStar2 PCi alexyug Satellite PC Card Receivers & Internet by Satellite 1 23-02-2004 09:45 AM
BFBS cryptoworks Zorba Conax, Cryptoworks, Nagravision, NDS and Others 8 18-01-2004 11:32 PM
cryptoworks andy-gi Satellite PC Card Receivers & Internet by Satellite 1 27-10-2003 04:00 PM
HELP Cryptoworks ORF gecko Conax, Cryptoworks, Nagravision, NDS and Others 5 02-09-2003 03:58 PM
