ROM110 AC3 unlooper help?
CAMs, built-in CAMs, Common-Interface CAMs...
Add-on decoders.
Old 01-06-2007   #1
My System: Echostar ad3000ipva motorised setup
Hi
I know this is an international Portuguese forum,but I am looking for expert help.
I have a rom 110 ac3 card.
I have been using rom110 studio v1.6
I am trying to set up my unlooper to glitch into the card.
I have used a resistance of 2.2k on the variable resistor unlooper and PSU at 9v but the response was bad.
The response was nothing like the one given in the rom110 studio document.
I tried to set up the resistor,and found 50ohms to give a good response.
Would it be better to leave the variable resistor at 2.2k and adjust the vcc start and vcc limit in the configuration menu?
Sorry for the post being in English.
Babelfish translator very bad in your language.
Theres not much point in me making a post in the English forums either.
I cant see many English posts in regards to mosc rom110 ac3.
Any help would be appreciated.
caketin
caketin is offline   Reply With Quote
Old 18-03-2008   #2
My System: dvb rom102 usb atmega256 atmega128
Im assuming you are using a powersync unlooper. 2.2k ohms was used for the hu cards way back when dtv was hacked. try setting your pot between 180-220 ohms and you may find you have better results. Good luck!
ooops! just noticed the date of your post, guess im a little late...lol
skybandit is offline   Reply With Quote
Old 06-07-2008   #3
My System: todo sobre satelit
ola amigos como emcontra rom110 studio v1.6 ñ acho
rejao is offline   Reply With Quote
Old 08-07-2008   #4
john_graydon's Avatar
My System: Dusty Dreambox 7000s, & Sky HD.
Originally Posted by caketin View Post
Hi
caketin
You will need to flash your glitcher with newdrs. You will need rom 110ac3 script. 4619 chips installed on your glitcher. Make sure you dump your script 1st.
Você precisará de piscar seu glitcher com newdrs. Você precisará o certificado da ROM 110ac3. 4619 microplaquetas instaladas em seu glitcher. Certifique-se que você despeja seu certificado ø.
Happy Dreaming
john_graydon is offline   Reply With Quote
Old 10-07-2008   #5
John_graydon
trying to pm you but i dont have a reply option in my pm box.
Old 10-07-2008   #6
Amo Amas Amant Admin
Topper's Avatar
Ermm
Originally Posted by skybandit View Post
John_graydon
Sorry PM privileges are not available to new members you will have to post your question provided it is within the rules which I am sure you read
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 12-07-2008   #7
i was just trying to reply to his pm.. no worries
Old 24-07-2008   #8
My System: DM500s only at the mo.
Can this be done with a powersync? Is there a script for ac3 or do I need to use the romstudio program? Not sure what you mean by dump your script?
Sorry for the noobish questions, hope I'm not outta line either.
fatbunny is offline   Reply With Quote
Old 24-07-2008   #9
Topper's Avatar
Ermm
Thread moved from Portuguese section
Show Your Support
Thank you.
ac3, rom110, unlooper
