Canal Digitaal Smartcard Authorisation | |
| Member Join Date: 01-06-2005
My System: Echostar 3600, Sky Digibox, NTL |
Hi All, I have recently purchased (from a company in the uk) a Canal Digitaal smartcard with the family pack and I am having some problems trying to get the card to work, aparently the card has been authorised but all I seem to get is the message "Video Scrambled check your rights" does anyone know what channel I need to be on in order to receive the necessary codes, I've so far tried leaving it on RTL4 for several hours with no luck. Thanks. | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
I have to say I am a bit puzzled I was under the impression that Canal Digitaal required a dutch address before a card could be bought
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| Regular Member Join Date: 18-11-2004 Location: Belfast, Northern Ireland
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn. | I got mine from a Company in the Netherlands. Contact your supplier as mine went off once but a quick email had it back running in 3 days. Was told to leave it on SB6. | ||
| Double Dutch Dude Join Date: 29-05-2004 Location: Netherlands, Veenendaal
My System: Dreambox 800 HDTV with a Visiosat Big Bisat | If you leave the receiver on Channel SBS6, the card will be activated within ten minutes.
__________________ With kind regards or Met vriendelijke groet, ANZO | ||
| | #5 | ||
| Member Join Date: 15-02-2007 Location: UK
My System: SAT | Hi Sat Friends I have a dutch smart card you can switch back on your dutch card by going to this CanalDigital website to switch back on your card. Once you have done it leve your smart card on Ned1. http://www.canaldigitaal.nl/default.asp?id=302 | ||
