Move CAM and Card to another receiver
Discussion on the Canal Digitaal Satelliet Nederlandssatellite TV subscription packages.
Old 10-08-2009   #1
My System: Technomate 5400 CI+ USB, 105cm Gibertini dish, Smart Titanium LNB (0.2 db); FloppyDTV (2) in HTPC.
We are moving offices at work and so I have use of a subscribed Canal Digitaal cam and card for a few weeks before the dish is put up at the new location. What do I need to do to be able to use the card in my receiver? In the office, there is some off-brand cheapy receiver that it works in and and home I have a Technomate TM-5400 CI+ USB.
Do I need to do anything to match the cam or card to the receiver so that it works?
Thanks much!
timhan is offline   Reply With Quote
Old 10-08-2009   #2
Just insert the Cam into the CI slot on your receiver, it might even work in the card slot, if your receiver has one.
You will need to ensure that you have all the Canal Digitaal channels scanned in.
Mickha is online now   Reply With Quote
Old 13-08-2009   #3
Jan Luc Piccard's Avatar
My System: No setup
It should work with the latest firmware according the info I have but to be honest I can't check it.
Jan Luc Piccard is offline   Reply With Quote
cam, card, receiver
