Help on Tequila channels pleaseMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Regular Member Join Date: 04-02-2004 Location: Essex
My System: Echstar 3600IP 1.1M dish cas3 Matrix MRV |
Can some one give information on how to make a card for the Tequila channels. I have Infinity Pheonix programmer and Fun cards6, Matrix reloaded Cam. Please tell me if my equipment is right for the job? | ||
| Specialist Contributor Join Date: 05-04-2004 Location: Manchester, UK
| Hopefully these instructions should help: http://www.satellites.co.uk/php-bin/...ead.php?t=9384 0064 is the provider (Digital Plus), which is under the Seca3 option of the MR 1.080. The keys you need to edit are 0c, 0d and 0e. For the latest keys, try www.rdi-sat.com and download a mach1 file with the latest mr keys. If you are still having probs, have a read of the matrix thread: http://www.satellites.co.uk/php-bin/...splay.php?f=53 Regards | ||
| | #7 | ||
| Back to your original question then For MR 1.080, a titanium card is needed now (cannot be done with fun cards). It may work without card on a lower firmware (MR 1.060), but I haven't tried this myself so can't confirm. It's only Taquilla 1-10 as well. Regards | ||
| | #9 | ||
| Regular Member Join Date: 29-01-2004
| hi nitefire.after you download the file ,you will then open it and it will show you the code/numbers,you then open your conditional access on the program menu on your receiver and pick which keys you want to change ie seca, nagrivision/ect..hope this goes ok for you | ||
| channels, tequila |
Similar Threads | ||||
| Indian DTH: Dish/TataSky/DDDirect+ (All Info) V2 | Analoguesat | Dedicated DTH (India and Region) | 706 | 05-09-2006 12:25 PM |
| Indian DTH: Dish/TataSky/DDDirect+ (All Info) | URPradhan | Dedicated DTH (India and Region) | 634 | 04-08-2006 10:09 AM |
| English Audio on satellite channels | cowboy | Transponders & channels | 11 | 23-02-2006 01:08 AM |
| New RAI channels | net1 | Transponders & channels | 1 | 05-01-2004 04:42 PM |
| Erotica channels launch. | net1 | Adult satellite channels | 0 | 24-06-2003 07:38 PM |
