What do I need?
MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them
Old 16-07-2008   #1
My System: Topfield 5500PVR
What do I need?
Hi all,
I have a Topfieled 5500PVR pointing to Astra at 19.2 I will soon upgrade the dish to point at Hotbird at 13 too.
I'm main interested to manage to view erotic pay-tv senders. What CAMs, cards do I need and do I also need card programmers?
Thanks,
cryo
cryo75 is offline   Reply With Quote
Old 16-07-2008   #2
Archived Member
Originally Posted by cryo75 View Post
Hi all,
Thanks,
cryo
Welcome to Hot Bird 13E.
You might find this thread useful, as it tells you about adult channels quality, their encryptions and package names. (MV channels have gone)
Adult Channels Quality on Hot Bird
If your receiver has a cam slot or CI slot, try to find out which encryptions does it supports before deciding on the package, otherwise you might need to buy another receiver to match the card encryption option that you might buy.
Viaccees and Irdeto are the most popular.
Check out our site sponsors page offers.
http://www.satellites.co.uk/index.php?page=sponsors
HB13DISH is offline   Reply With Quote
Old 16-07-2008   #3
My receiver has to CI slots. I think one is an integrated Conax and the other is free, ie. I can place any CAM I like.
I would like to purchase a CAM that lets me be free programming it, ie. one time I use it for Premiere, other times for Dorcel, Spice, Hustler, Playboy, Arena, etc. I know this would mean different cards & keys but I believe the most important thing in this kind of setup is the CAM, or?
Thanks,
cryo
Old 16-07-2008   #4
Archived Member
cryo
Try to check the encryption support of the CAM from the manual or ask the manufacturer or his distributor. Don't assume anything when it comes to CAMs.
Old 17-07-2008   #5
Well, I guess I would need a second CAM in the other slot if I want to open up other channels with different cards, right?
cryo
Old 17-07-2008   #6
Archived Member
cryo
First of all check which encryptions the other CI slot can support before buying any cams.
For example, it will not support NDS for sure. Take it from here.
Old 17-07-2008   #7
The Conax slot supports only Conax. The other CI slot is empty and I would need a CAM for it.
Old 17-07-2008   #8
Archived Member
You are missing the point.
The other CI slot MAY NOT ACCEPT any CAM.
Try to find out which CAMs it will accept, before buying any cams.
Old 17-07-2008   #9
I've checked and it accepts all CAMs that conform to the CI standard.
cryo
Old 17-07-2008   #10
Amo Amas Amant Admin
Topper's Avatar
Ermm
cryo
Any manufacturer will claim that but the reality is some stb's do not work with certain cams....just be aware of that
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 17-07-2008   #11
Back to my original question, what CAMs do I need and would I need smartcards to program the CAMs or what?
cryo
Old 17-07-2008   #12
Topper's Avatar
Well
cryo
I do not know I do not watch programs like that, I suggest you read the relevent sections of the forum. I would however suggest that only a modern CAM such as the Dragon or Trex would have the processing power for today's encryption systems. For sure programming CAMS with cards is very old hat now and most people use a CAS II or CAS III programmer
Show Your Support
Thank you.
Old 17-07-2008   #13
Does a Cas3 programmer require a smartcard or is the cam inserted directly into the cas3?
Another questions... I see lots of these keys. where are they entered? using the cas3 programmer or sat receiver itself?
cryo
Old 17-07-2008   #14
Archived Member
As you have now the dish pointing to Astra 19.2E, which CAMs are you using already?
Surely there are some interesting channels and packages there.
Have you checked if your model is patchable?
Might save you buying CAMs.
Old 17-07-2008   #15
The Cas 3 can program Dragon/T-Rex cams without the need for a card, it uses a dummy card, an oblong circuit board, connected to the Cas 3 and inserted into the cam.
You need a Cas programmer to update the Diablo Cam, currently the best cam on the market as the 2.3 model opens Canal Digital 1W, and DigitAlb 16E, but for how long they stay open is anyones guess.
You can update keys using your receiver and remote control but only for available packages.
Mickha is offline   Reply With Quote
Old 17-07-2008   #16
@HB13DISH:
I'm currently pointing to Astra 19.2 but I still have no CAMs. I will first update my setup so I can also point to HB at 13 and then check what packages are available.
What do you mean by patchable?
@Michka:
This means that I should consider getting the Diablo 2.3 Cam & Cas3+ programmer. This should open up most packages on Astra and/or Hotbird.
What do you mean by 'You can update keys using your receiver and remote control but only for available packages.'? Do I enter the keys in the CAM using Cas3 or the receiver?
thanks,
cryo
Old 17-07-2008   #17
Topper's Avatar
Ahem
I would say the statement above from my previous post answers your question but if you want to know more go have a read about the Duolab products
cryo
All depends on where you are seeing them as you do not say I cannot answer. This hobby is not something you can learn over night it is also not possible to just give one word answers to question. These aspects have been covered in previous posts. The idea of a self help forum is that you read about the particular aspect of the hobby you are interested in then start asking questions. If you want a good overview of cams and encryption systems then here is a good read
Show Your Support
Thank you.
Old 17-07-2008   #18
Let's say I want to open up Hustler TV. What are the tools that I need?
cryo
Old 17-07-2008   #19
In this hobby you can't just select channels that you want to view, unless you wish to subscribe to the package carrying those channels.
Currently you can view Hustler TV on 5E, which is why it is a good idea to have a motorized dish set up.
A motorized dish allows you more viewing options for future requirements.
We have had Premiere 19E, Polsat 13E, TPS 13E, and Digi TV 1W open for some time now but these packages are upgrading their encryption and will not be available much longer.
For guaranteed viewing you need to subscribe to a package, like DigitAlb 16E, which provides a mixture of sport, films and porn channels.
If you think of viewing satellite channels as a hobby rather than a way of getting free television then it begins to make more sense.
We are never sure what we will be able to get, and sometimes we don't get a lot of viewing choices, but when a package is opened, like Digi TV, we get a lot of satisfaction from viewing these channels.
You will see a lot of mention regarding feeds, these are usually sporting events being transmitted across other satellites which we occasionally can pick up, this is another enjoyable part of our hobby.
I suggest you have a read round the forum cryo and decide what will suit your needs best, whether you wish to subscribe to a package, for guaranteed viewing, or take a chance and join the satellite hobby.
Many members do both and subscribe to a package but also scan the satellite arc for feeds and hacked packages.
