is it posible to copy this card?
MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them
Old 22-10-2008   #1
My System: Satellite Dish 3m mesh, Cakrawarta-1, Humax ND 2200s
I'm a total newb about this topic. I am just wondering if it is posible to copy the card provided by the satellite tv provider? I'm not sure if it is IRDETO or IR2.
I have 2 decoders atm but only have 1 card so I split it but both tv will have the same channel.
If it is posible, what software/hardware do I need? Thanks in advance
P.S. I think we're using Cakawarta-1. Im not sure if it is ok to mention the name of the provider so i wont mention if yet.
Swack is offline   Reply With Quote
Old 22-10-2008   #2
Prince of Birthdays
dig deep's Avatar
My System: Dream7020 and AZ Elite
Nowdays all cards are very secure copy-protected
But there is a thing called cardsplitter, havenīt tried one but they seems to work fine.
Do a Google
dig deep is offline   Reply With Quote
Old 22-10-2008   #3
Archived Member
Yes card splitters might be a good solution.
Seen it in our site sponsor Sateuropa
_http://www.sateuropa.co.uk/overview.asp?catid=10&subcat=55
On the other hand, your provider might have a big discount for a second room subscription. At least this is what our local provider does.
HB13DISH is offline   Reply With Quote
Old 23-10-2008   #4
Thanks for the quick replies. If im going to buy a card splitter, what type of receiver should i get? DBox seems to be very famous, will that work with the splitter?
Old 23-10-2008   #5
Archived Member
I don't understand the question.
Your first post mentions that you have already two decoders and I assumed you mean a satellite receiver.
What is a decoder in this case?
Please give more details. Make and model number.
Old 24-10-2008   #6
Sorry for the confusion, yes I have 2 decoder/receiver at the moment. Reciever is sometimes called decoder right? Please correct me if i'm wrong, because I dont know if that is right. I have Humax ND2200S and old Motorolla which I dont know the model. I just asked because i saw that the wifi card splitter comes with 3 client cards, so I might as well buy another receiver to use the third client card on another tv.
Old 24-10-2008   #7
Archived Member
OK. Let's stick to the terminolgy of "receiver".
Before buying the card splitter, you should first find out if it will support your smartcard encryption or if it will work on both receivers.
So before buying a third receiver, get the two receivers to work first.
Did you ask your provider about a multi room subscription instead?
Old 25-10-2008   #8
Both receivers are working fine with the card because both came from the same provider too.
I checked the encryption used on Cakrawarta-1 and it is using Videoguard, But the card splitter i saw only supports Seca Mediaguard 1 & 2, Viaccess 1 & 2, Conax, Irdeto 1 & 2 and Cryptoworks encryptions. Will this work on Videoguard encypted cards too?
Will cardsharing using DB receivers work with ADSL 128/64kbps? I only want to use it on the same house/building incase the cardsplitter doesnt support my card encryption.
There is no provider here on my location right now and I only got my subscription by asking a friend of mine to buy me one during his last travel to Indonesia, so asking them about multi room subscription will have to wait until my friend's next travel there.
Old 25-10-2008   #9
Archived Member
AFAIK it will not work with NDS (Videoguard), unless you get confirmation that the card splitter will indeed work with your card.
Search for card splitters that work with Sky UK, as they are also NDS,
but I doubt if they exist.
Inhouse cardsharing could work, but it would mean buying two more receivers.
Perhaps it would be cheaper in the long run to buy another card or just take the card and insert it in the second room.
The Following User Says Thank You to HB13DISH For This Useful Post:
Swack (26-10-2008)
Old 25-10-2008   #10
Amo Amas Amant Admin
Topper's Avatar
Well
Yes I agree if I remember correctly somebody has already tried a card splitter with NDS and it did not work!
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
Swack (26-10-2008)
Old 26-10-2008   #11
Thanks for all the help guys.
card, copy, posible
