sky cards working in other digiboxesMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Member Join Date: 17-06-2009 Location: northern ireland
My System: pace digibox |
hi there can anyone explain this to me i borrowed my mothers sky card as she is on holliday she has the full package it worked for a few days and then stopped why did it work and can i somehow get it to work again many thanks ![]() | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | Just put it back in her box and it should wake up when it gets the update signal. | ||
| The Following User Says Thank You to Huevos For This Useful Post: | sparkieee (17-06-2009) |
| Specialist Contributor Join Date: 05-04-2008 Location: Costa Blanca, Spain
My System: 1.8m PF Dish, most sky and freesat recivers, 80cm on Illusion motor and Dreambox DM7025, TDT | it depends on what the messages are on the screen (and if you are using it in a sky receiver or not!) normally sky card will work in any sky receiver - for the "6 mix" channels, and not the sports and movuies channels. For these two you will see the "this is the wrong card for this set top box". HOWEVER I have also seen this message as part of the new card change over...it appears ON ALL ENCRYPTED channels if your sky card has not been paired to the box and sky have sent the new card out....if it was paired then you would see the "insert new card" message. | ||
| The Following User Says Thank You to woborny For This Useful Post: | sparkieee (17-06-2009) |
| | #5 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Probably only if you use the other digibox. | ||
| | #8 | ||
| Regular Member Real name: Steve Join Date: 14-04-2009 Location: Co. Tyrone
My System: DM500s, DM7020si, DM600s pvr, 1m Triax Advent 9415 lappy | Not exactly sure.. But i would think sky noticed that it was not in the box that it was married to.. so ther-fore it will not work.. It should work again after you put it back in your mothers box and it gets an update.. take the box and the card next time.. lol | ||
| The Following User Says Thank You to wannabee For This Useful Post: | sparkieee (18-06-2009) |
| | #9 | ||
My System: pace digibox | cheers wannabee i was goin to but she wud av tru a fit shes old she dosentlike any thing being touched shud i try putin it back in her box and then back in mine to see if i can get it to work again shes back on saturday | ||
| Last edited by sparkieee; 18-06-2009 at 12:19 AM. Reason: incorrect spelling | |||
| | #10 | ||
My System: DM500s, DM7020si, DM600s pvr, 1m Triax Advent 9415 lappy | It may take a while to get it going again in your mums box again.. via sky update Depends if you want to rub your mum up the wrong way when she gets home. lol | ||
| | #13 | ||
| Specialist Contributor Join Date: 09-02-2008 Location: Newtownabbey, near Belfast, Northern Ireland
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east. | Would the fact that Sky see to be sending out updates to the blue cards on an almost daily basis have caused this, because as has been stated the only channels that should not open are the movies and sports, My blue cards are getiing two day extensions nearly every day | ||
| | #14 | ||
My System: 1.8m PF Dish, most sky and freesat recivers, 80cm on Illusion motor and Dreambox DM7025, TDT | your card worked ok in another receiver until sky sent the messge that your new card has been posted. this message then checks to make sure you are using the cad in the correct box - as this is required to activate the new card. it shows the "not correct card" as a warning that you are not using the card in the correct box, to call sky, as you will not be able to activate your new white card in the nonpaired receiver... so both you old and new card will not only work in your mums receiver (or the one that the card is originally paired). if you want TV use your mums receiver... or get her white card when it has been activated! | ||
| | #15 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #16 | ||
My System: 1.8m PF Dish, most sky and freesat recivers, 80cm on Illusion motor and Dreambox DM7025, TDT | lets just say that during this card swap phase there have been some interesting reports.... including the freesatfromskycards being able to record and playback FTA channels in Sky+ receivers, some "replaced" blue cards still working ok in sky receivers...for all (inc sports and movies) channels...old cards still workinng in nosky receivers... i suppose things will not be 100% until the old NDS2 encryption is totally switched off... | ||
| | #17 | ||
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east. | | ||
| | #18 | ||
| Member Join Date: 09-04-2009 Location: Buckinghamshire(H.Wyc)
My System: Moterk 2100a motor on 80cm dish,16'E-18'W Manhattan XT-CM receiver. Fixed Sky dish 28'2E | | ||
| cards, digiboxes, sky, working |
