Dragon Module?MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| | #26 | ||
| Regular Member Real name: Chris Join Date: 20-07-2009 Location: South Coast, Hampshire
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | Hi Mickha, I have been playing with the cas 3 for some time now without success. I have tried pushing the dummy card all the way in as well as trying it out a tiny bit more each time and still no joy. When you say switch the connections around I take it you mean try the cable plugged up with the end that was on the dummy card on the cas3 instead, not try to plug either connector up the wrong way round. I haven't got a loader card at present but I have put a bid in for one on Ebay I am putting the cam in with the dragon label upwards and the dummy card in with the contacts upwards and the connector underneath. Could it be a fault on the cam contacts? | ||
| | #27 | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | Hi Mickha, I have definitely got the connectors on the dummy card the right way up and I have tried swapping the plugs around so that the end that was in the cas 3 is now in the dummy card but I just get the same result. I may have to wait until I get a loader card and try with that to try and prove if it is the cam or the cas3 which is giving the problem. I bought both items on Ebay | ||
| | #28 | ||
| Super Moderator Join Date: 10-12-2004
![]() | There is no problem with the twin module but it could be a faulty Dummy Card, I seem to remember there being a problem with a few of them. All I can suggest is that you keep trying as the Cas 3+ must be working to allow you to use the Common Interface Host option and enter the Dragon Cams menu. | ||
| | #29 | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | Hi Mickha, I have tried and tried but nothing makes any difference I have tested all the components on the dummy card and they all seem to be okay. I may take a run down to Yeovil tomorrow and ask Skywise if they can test the cas 3 for me as their label is on the outside of the unit, so they might give me some help. I guess I should have bought one from a shop rather than off Ebay | ||
| | #30 | ||
![]() | Were the Cam and Cas 3 bought as a package, or separate purchases? There are 2 versions of cards that can program a dragon cam, a Funcard 7 (Prussian Card 5) and a PIC F84a Dragon loader card, if there is a problem with the Dummy Card it might be cheaper to buy a Funcard 7. Hopefully the shop can test it for you and solve the problem. | ||
| | #31 | ||
Hi Mickha, The cas3 came with a diablo cam and it looks like the unit had never been used for programming anything using the dummy cam as there were no marks at all on any of the contacts before I started using it. The Dragon came came from a second auction on Ebay There were several other reports of the dummy card not working and from what I read I suspect it might be a problem with the software as I noticed someone running an earlier version of the software said that his unit was working okay. I am still in the running for a loader card on Ebay Thanks for all the help so far. In the meantime I tried updating the Diable 2.3 cam that I have got using the cas3+ did that in about five minutes flat, so it now has 182 software ibnstead of 181. | ||
| | #32 | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | I should add that as I saw that it was a common problem I didn't bother driving all the way to Yeovil as I thought it would be a waste of time and petrol. | ||
| | #33 | ||
![]() | There was no need to update the software on your Diablo 2.3 cam, the last update was just to fix a few bugs using a subscription card. I am still using Underworld 181 and can open Digi TV, 1W, and the Irdeto 2 encrypted Canal Digitaal channels on 19E. Seeing as your Cas can program a Diablo Cam your Cas 3 is working, and I assume you're using the Cas Studio 8.6c software, equally as it can read you Dragon Cam, without the Dummy card, using the Common Interface Host option, then I still think the problem lies with the Dummy card. You can pick up a new Fun Card 7 loader card for around £10, so don't bid too much on Ebay | ||
| The Following User Says Thank You to Mickha For This Useful Post: | Crisbe (15-08-2009) |
| | #34 | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | Thanks for that last piece of advice. I have only bid about a fiver so far so I will see how it goes. | ||
| dragon, module |
