Dragon Module?MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Cost efficient Muppet Real name: Waqas Join Date: 19-11-2008 Location: United Kingdom
My System: Satellite 1m Orbital?, Moteck DiSEqC 1.2 Motor (SG2100A), Galvanised T&K brackets and a pole, megasat 0.1dB LNB, (Kit was bought from eBay-sorry for not being more specific) ---------------------- Computer: CPU: AMD X2 4850E, Mobo: Foxconn 6 |
Well, Ive seen a dragon module, dynamite programmer and a funcard 7 on Ebay Im sorry if this is in the wrong section, but I thought this section would be the best for a question like this | ||
I regret to say the days of the equipment you are being offered are numbered as all encryption systems bar one are now totally secure that being Digi TV at 1 deg West which is in the middle of a card/encryption change. Very useful as a learning tool though but no chance of any long term viewing from it | ||
My System: Satellite 1m Orbital?, Moteck DiSEqC 1.2 Motor (SG2100A), Galvanised T&K brackets and a pole, megasat 0.1dB LNB, (Kit was bought from eBay-sorry for not being more specific) ---------------------- Computer: CPU: AMD X2 4850E, Mobo: Foxconn 6 | Well, if it works for one month Im happy! As the programmer is probably worth £20 and the funcard a fiver(I think anyway) | ||
| Super Moderator Join Date: 10-12-2004
![]() | The Dragon module probably is the Dragon Cam. Find out which version it is, as the early models have problems with the later Predator files. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | Waqas Ahmed (01-07-2009) |
| | #5 | ||
My System: Satellite 1m Orbital?, Moteck DiSEqC 1.2 Motor (SG2100A), Galvanised T&K brackets and a pole, megasat 0.1dB LNB, (Kit was bought from eBay-sorry for not being more specific) ---------------------- Computer: CPU: AMD X2 4850E, Mobo: Foxconn 6 | Just asked that question to the seller now. What version of the cam should I buy? | ||
| | #6 | ||
![]() | The last version was the T-Rex 4.6 super module, the one previous was the Dragon twin 4.1 also known as the T-Rex v1.0, prior to that was the 3.01, and the earliest was the 2.06, this is the one that can't seem to handle the later Predator files. | ||
| | #7 | ||
My System: Satellite 1m Orbital?, Moteck DiSEqC 1.2 Motor (SG2100A), Galvanised T&K brackets and a pole, megasat 0.1dB LNB, (Kit was bought from eBay-sorry for not being more specific) ---------------------- Computer: CPU: AMD X2 4850E, Mobo: Foxconn 6 | The seller confirmed today it is the version 3.01. Does this one have absolutely no problem with any files? | ||
| | #8 | ||
![]() | Only by testing it can you know that but most owners of the 3.01 use the last Predator 369 file, ask the seller which version of Predator he has loaded on it and if there is any problem with Digi TV. Also check if it's had to have the bootloader repaired, a common problem with Dragon Cams. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | Waqas Ahmed (03-07-2009) |
| | #9 | ||
My System: Satellite 1m Orbital?, Moteck DiSEqC 1.2 Motor (SG2100A), Galvanised T&K brackets and a pole, megasat 0.1dB LNB, (Kit was bought from eBay-sorry for not being more specific) ---------------------- Computer: CPU: AMD X2 4850E, Mobo: Foxconn 6 | Thanks. Ive now asked the seller the questions above. Is Digi TV the only TV provider left that a patch/cam will descramble. Or can patches or bin files open other sats. If there are no other patches/cams ah well.. still get lots of FTA channels | ||
| | #10 | ||
![]() | Digi TV is the only real package, but there are a few other channels available, they will be listed in most modified Predator 369 files. | ||
| | #11 | ||||
My System: Satellite 1m Orbital?, Moteck DiSEqC 1.2 Motor (SG2100A), Galvanised T&K brackets and a pole, megasat 0.1dB LNB, (Kit was bought from eBay-sorry for not being more specific) ---------------------- Computer: CPU: AMD X2 4850E, Mobo: Foxconn 6 | Sorry if this sounds really stupid, but then again I am a cable muppet , I have a linux receiver(Openmedia 500cs) Is it possible to transfer some BIN files to it without the need of a hardcam?Also I emailed the seller and said
| | #12 | ||
![]() | Predator files are the firmware that is loaded onto a Dragon Cam so the seller should be aware of this, if he has used the cam, 369 was the last version produced, almost a year ago. It's a little surprising that he hasn't used this file as when it was produced there were lots of channels available including Premiere, Digi TV and probably the polish package. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | Waqas Ahmed (04-07-2009) |
| | #13 | |||
| Member Join Date: 17-06-2009 Location: Mainport Of Europe
My System: Echostar 2200Ci Viaccess, Echostar 3000IP Viaccess CTech 2100Plus and M-Vision 200HD | You can't compare the T-Rex 4.6 with the Dragon 4.1 & T-Rex 1.0 the T-Rex 4.6 got 1) a bigger memory. 2) security Update and also you can make use of the PreD 3.69 or PredaS 2.29 files Never put a Predasaurius file in a Dragon or T-Rex 1.0 module. | |||
| | #14 | ||
![]() | Secure updates for the T-Rex 4.6 super module never lasted very long, in fact it was the last throw of the dice from the Dragon team and they just made quick money from that cam. The T-Rex 4.6 can use Predasaur, or Predator files, and although it is superior it only opens the same packages and has done for a long time. It is very unlikely that there will ever be another official release of an updated Predator or predasaur file,and it does not look like they will release the source code so that others might update it. All we can do is update keys and add/change providers, using the software tools available, which wont be enough to be useful in the future. At the moment it can still open Digi TV, and a few other channels, but eventually the cam will be of more use as a card reader than anything else. It's unfortunate but the way of this hobby, the same happened with the old Magic Modules, the Matrix Cams and other multi cams, and will no doubt even happen to the Diablo 2.3. You're right a Predasaur file wont work in other Dragon/T-Rex cams but you can recover a cam that has been loaded with the wrong file, and if you check both Predator and Predasaur files in a Hex editor you wont notice much difference. You might as well ignore Predasaur files and stick to Predator files, as they both do the same thing. | ||
| | #15 | ||
My System: Echostar 2200Ci Viaccess, Echostar 3000IP Viaccess CTech 2100Plus and M-Vision 200HD | Mickha I heard your story so many times but still i believe that the Dragon 4.1 & T-Rex 4.6 will come back with more then those channels below what they receive now: SWISS CABLE Digi TV RAI MEDIATECH GLOBECAST TV GLOBO EUSKALTEL DREAM TV CRYPTOWORKS Kingston BISS Included with these channels: TRT1 42E TRT3 42E EKIN TV 42E RUSTAVI2 42E Mick/MTV 33E TET 5E FOX SPORT ME 25E NGEO GER 12.5W ROUGE FM 13E LIDER TV 13E SAT 2000 9E FOX TV 12.5W FOX GERMANY 12.5W ENTV 22W 1+1 Inter 4W Megasport 4W TV KYIV 4W FOX LIFE FR 5W FOX SPORTS ME 8W DISCOVERY CHANNEL ME 8W FOX NEWS 8W AL RAIE 8W MBC Inter 26E TV CANARIA 30W MTV TRAX 28E DCW | ||
| | #16 | ||
![]() | That's one of the first times I've posted anything negative about the Dragon Cam, but it is very difficult to see any further official support, for the cam, as even the official sites closed down quite some time ago. The channels, you have mentioned, are all available on general emulation and are only available because other members have updated keys, and providers, using software tools like PredEdit and even Hex editors, not because of official support, but as I've mentioned we can only do so much ourselves as the source code is secret. At present their is nothing new available, on general emulation, and if there is a future breakthrough, maybe in Nag 3 or Conax Cas 7, then we might need the souce code to get the Dragon opening these channels, until then we can't be sure. I wouldn't advise anyone in buying a new cam yet, and certainly not a Dragon/T-Rex cam. | ||
| | #17 | ||
My System: Echostar 2200Ci Viaccess, Echostar 3000IP Viaccess CTech 2100Plus and M-Vision 200HD | Mickha I agree with you but that count also for smartcards and cheap receivers with 1 month support. Glenn_911 | ||
| | #18 | ||
| Regular Member Real name: Chris Join Date: 20-07-2009 Location: South Coast, Hampshire
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | I have just aquired a cas 3+ programmer and a couple of cams on Ebay How do you test a cam using the cas 3+ ? The online guide doesn't exactly tell you that bit. I tried the dragon 4.1 firecrypt cam in the cas 3 and got a message "no cam". Does that mean that there is a fault with the cam or that it needs software loading in to it? This may seem a dumb question but unless I ask I won't learn will I? I have downloaded and printed the cas 3 user manual and made sure I did everything the way the pictures said but, as I said, so I don't think it is a connection problem. The cam has a small sim card in the second slot. Should I remove that? Advice would be appreciated folks, be gentle with me i'm an old man! | ||
| | #19 | ||
![]() | The Sim card is more than likely an old Access 9 porn card, they were supplied free, at one time, when you bought a Dragon Cam. To program a Dragon Cam with the Cas 3 you need to use the Dummy Card, the oblong circuit board that connects to your Cas 3 using the 20 pin ribbon cable, you then insert your Dragon Cam, into the Cas 3, and insert the Dummy card into the Dragon Cam, with the "Cas Inerface Dummy Card" text facing upwards. You then start up the CAS studio 8.6c software, click on the Cam Module tab, and the Dragon Cam icons, ensure the version is set to 3.x-4.x. Your Cam can only take Predator software, so download any version of Predator 369, the last one produced, and place predator369.dra on your computer desktop, it makes it easier to navigate to. Click on the little icon, with 3 dots, at the end of the File Name address bar and navigate to predator369.dra, on your computer desktop. Click open and Start Update. Have you tried your Cam in your receiver? If it was bought second hand it might already have Predator 369 loaded on it, try inserting it into your receiver and navigating to the Cam menu, or insert your Dragon Cam in your Cas 3, start up the CIS 8.6c software, click on the Utilities tab and the Common Interface Host icon, this should be able to read your Cam. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | Crisbe (13-08-2009) |
| | #20 | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | Hi Mickha, thanks for the reply, I tried the cam in a D box with DVB2000 software and the led display gave me a message "cam sucks" so I figured that either the cam was not programmed or had the wrong software in it to be compatible. So I tried to test it in the cas 3+ but wasn't sure how to do it. I tried the repair utility and it just said "no cam" so I thought it would be better to ask guys who know before I did anything else. Silly question: (remember I am only self taught on computing, having grown up in an age when we didn't even have pocket calculators!) Do I have to expand the dra file before loading it. What I mean is: Is a dra file something like a zip or rar file, or is dra just a name for the file? | ||
| | #21 | ||
![]() | .dra is the official file extension of Dragon Cam modules, these are the only files that can be loaded onto the cam. Try the Cam in your Cas 3, insert the Dragon Cam into the Cas programmer, you don't need the Dummy Card for this, start up the Cas Studio 8.6c software, click on the Utilities tab and the Common Interface Host icon, this should now display the contents of the Dragon Cam. | ||
| | #22 | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | Thanks Mickha, I am just going to try it now and will get back to you later to let you know how I got on. | ||
| | #23 | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | Hi Mickha, I have just tried the cam the way you told me and it came up with predator 3.49, so I am just going to try loading the 3.69 the way you told me. | ||
| | #24 | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | Hi Mickha, I have just tried loading predator 369 in to the cam and the cas 3+ keeps telling me that the dummy card is not inserted, even though it is. I checked with picture in the user guide and also with what you said in your previous post and it all looks okay. The cam still tells me that it has got predator 3.49-0809 installed, so it obviously hasn't written anything to the cam. Am I missing something obvious? | ||
| | #25 | ||
![]() | Ensure the 20 pin cable is connected properly, try switching the connections around, I had to do that with my Cas 3, also try pushing the Dummy card fully in. Have you got it the correct way up? You should be looking at the 8 silver connectors, 2 rows of 4, and the 20 pin connection should be underneath, keep trying it should work. Did you get a loader card with the Dragon Cam? As you can also program this to update your cam. | ||
| dragon, module |
