Problems with ViaccessMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Guest
Posts: n/a
Hello digital lovers !!! I have read "all" about 'how to/faq', but still I have some questions. Mainly because my equipment don't work with "Swedish" Viaccess (Viasat) channels !!! So I have wrote down what I have done, with some assumptions and questions. My equipment: ============= - Receiver : Nokia 9311S (bought with CANAL Digital for 12 months, Sweden) - CAM : PCMCIA ViACCESS... VIASAT DVB white triangle (these text on one side, see Q4.1) Next side# P/N: 902532 Rev 1.0 SCA:001, DVB number: 001608 - Card : one PIC16F84 24LC, see Q2.1 - Programmer: Multiprogrammer VER 3.3 970214 with software Multiprogrammer 5.93, see Q1 - Dish : My old Chinese Wook (this whas a bad joke), I suppose a standard dish - LNB : 2*Universal one's, pointing to 1 and 5 degree from Sweden --------------------------------------------------------------------------------------------------- Q1.1 I have an old programmer Multiprogrammer VER 3.3 970214 with software Multiprogrammer 5.93, this was bought from AD-teknik Sweden. Have earlier used this programmer to program my card with d2mac keys (i.e. MULTIMAC) to my analog receiver. I think I can use this programmer to program my card (see Q2 & Q3), is it right ? Q1.2 Or most I upgrade to or get another programmer ? Q1.3 If Yes to Q1.2 what is recommended ? Q2.1 I have a card with one PIC16F84 24LC. I suppose this is the card that is called Goldcard and it should be possibly to use to get access to "Swedish" Viaccess channels ? Q2.2 Or are there any other type of cards that works much better (see Q2.3) ? Q2.3 I know a person that uses something called MegaPic, found this: "MegaPic is a brand new card with a microprocessor. It has 16 k memory in pic and 8 k memory in eeprom." is it recommended to get this type of card insteed of a Goldcard and if so, what is the advantages ? Q3.1 I have talked to a person with a Nokia 9902 and he gave me a tip of files that works for him and others with Nokia, i.e. something called 'Viagold' and here some text from the file readme.txt "This is a new file for Viac**ss. Should be programmed as you normaly program a Goldcard. First program Ee-prom and then PIC. This version incl. special Ee-prom file for the shitty Nokia/Sagem reciever." I have used the files picfile.hex nokia_ee.hex (and also the file ee_prom.hex that works for 9902) and used my programmer as I used to do with the old "analog-files", but nothing happens ? After the programming I first put my card into the CAM with contact-side up (see Q3.3) and the CAM positioned as described in Q4.1 (and I think I have tested all other combinations too?). I tested on Swedish channel-3 and also TV1000, but nothing happens, what is wrong ??? Q3.2 I have waited severel minutes for the channel, must I wait even more ? Q3.3 I assume my direction (see Q3.1) of the card is right because: - I can see the contacts coming "down" from the thicker side of the the CAM, is this right ? Q3.4 Are the files described above not fitting with my Receiver "Nokia 9311S" ? Q3.5 If NO on Q3.4, are there any other files that fits with this particular Receiver ? Q3.6 Sometimes there is a *.bin file, is it only for progammers that must have it, my programmer seems only to accept *.hex-files ? Q4.1 I suppose that CAM-side with "PCMCIA ViACCESS... VIASAT DVB" white triangle (as I suppose pointing out the direction and side (up) to put the card into the receiver) is the "Up"-side ? Q4.2 Are the CAM sensitive (easy to broke) if I put it in with wrong side ? (Silly that this is possibly and I have tried both sides !!!) Q4.3 Is the CAM stupid hardware that not can be updated, or is it possibly to update the software on it ? Q4.4 If it possibly (Q4.3), what software are interesting to download ? Q5.1 A technician from the supplier where I bought my equipment, said to me that I have to download software from a side called "download" (page 499 in my channel table) to get Viasat or what ? Q5.2 I have tried that, but it's only said that no software is available ? Q5.3 But is this necessery to see for exemple Swedish channel-3, TV1000 ? Q5.5 What I have seen is this neccesery for some (all) receivers that want to use the Ticket channels, is that TRUE ? Q5.6 I have find a lot of download pages in my channel table, is there anywhone else that can be interesting for me ? Q6.1 What key-editors are recommended, found some one called "Zeeebra's VIAstrsh Hex Edit" is it good, or is it only for VIAstrsh-files and what is that ? (Opened the "Nokia-files" above with this editor and it seems like the editor can read them?) Q7.1 I have been toold that only Viaccess (Viasat) channels are "cracked" in Sweden, is that TRUE ? Q7.2 I assume above question is true, so I wonder why not CANAL Digital channels are "cracked" in Sweden ? and see below Q7.3 "No one" outside the Nordic-countries are interested to crack this channels ? Q7.4 They have a coding algoritm that is very difficult to crack ? ### Okey, I think is this enough for this time, Im looking forward to get some answers (Thanks) !!! @@@ And I will come back to tell you, (who are interested) when I get this to work !!! // And of course A Happy Good New Year to Everybody, Regards from Pekka the Swede with Finish nickname !!! | ||
| problems, viaccess |
Similar Threads | ||||
| R.R. Satellite Communications Ltd with Viaccess | net1 | Daily Satellite and Broadcast industry News | 2 | 13-03-2009 01:56 AM |
| Eutelsat satellite WC full channel coverage list | Analoguesat | Jimbo's Football and Sport | 0 | 07-06-2006 11:27 PM |
| Sky+ recording problems | pjb | Sky+ (Plus) and PVR Systems | 4 | 17-06-2004 11:46 AM |
| Few people seek help for sex problems | net1 | The Meeting Place | 0 | 22-08-2003 08:11 PM |
| Problems... Help ! | iwearflares | Analogue systems | 2 | 11-08-2003 08:01 AM |
