elvis for gamma?MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Regular Member Join Date: 08-06-2008 Location: england
My System: tm 9100 tm 1500 ci dm box 600 1 m dish polar mount 12 inc acuator v box 2 cas 3 dragon diablo gamma | never heard of one ..wasn t elvis programmer from years ago . cas 3 i use and gammaload programe | ||
| Super Moderator Join Date: 10-12-2004
![]() | There are conflicting reports, on how to load this card, one method recommended using Phoenix 3.579 Mhz mode on a PC but 6 Mhz on a laptop, which is a new one to me. Which loader program are you using? There seem to be at least 3 different loaders, and each file seems to recommend a different loader. | ||
| | #6 | ||
![]() | Using a loader is quite easy, once you have the programmer set in the correct phoenix mode, and have the correct com port selected. If you download one of the loaders, there are several different versions but all of them seem to have the same basic settings, the only 2 options you should be interested in are the Clean Card and Load File buttons. Clicking the Clean Card should restore your card then you can simply click on the load file option, navigate to the file, you have downloaded and unzipped, and let the program load the card. If you have ever programmed a Titanium, or MII card, before it looks very similar. | ||
| | #7 | ||
| Member Join Date: 05-10-2007 Location: somerset
My System: Technomate 6900 Super, !.1 channel Master,v-motor. Samsung 42"plasma | Thanks for the info fella`s, I am going to have a go using Multi-prog, Have waited and read up on the files for the g***a cards. | ||
| | #10 | ||
My System: Technomate 6900 Super, !.1 channel Master,v-motor. Samsung 42"plasma | The model I have is called Vegas, Its possible to select either pheonix mode, Which software are you using? And thanks. | ||
| | #13 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Just been looking at Duwgati.com and I'm pretty sure that the Elvis only has 3.58 Mhz phoenix mode. | ||
| | #14 | ||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| The Elvis programmer is made by AD-Teknik AB _http://www.adteknik.se The programmer datasheet mentions that it has a 3.58MHz Phoenix/Smartmouse interface. Looks like it doesn't have 6.0MHz option _http://www.adteknik.se/english/mp35ser.htm | ||
| | #16 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Try Multiprog.3.5"ELVIS" software V.1.60 or this version MultiProg V1.90 for MP 3.5 "Elvis" | ||
| | #17 | ||
My System: Technomate 6900 Super, !.1 channel Master,v-motor. Samsung 42"plasma | Thanks for your reply`s, I have multi-prog, I had hoped that someone might be using an Elvis to prog a g***a card and tell me how to do it. | ||
| | #18 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Depends what you want to put on it. You use multiprog to switch on phoenix mode, then use the relevant Loader program. Do a google search for "how to program a gamma card". | ||
| | #19 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | When you work out what to do make sure you give us a write up | |||
| | #21 | ||
| Member Join Date: 16-08-2007 Location: Australia
My System: KU Optus C1 65cm Optus D1, D2 90cm Humax 5410 Strong 4658X Relook 400 | I'm based in Australia and programmed my original gamma with a gam file many times using an Elvis. It's very straightforward, but I haven't done it since the local providers killed the original cards here in Sept 2007 | ||
| | #22 | ||
My System: Technomate 6900 Super, !.1 channel Master,v-motor. Samsung 42"plasma | Well I played around with muti-prog v1.90 and got no where, The Elvis programmer has a switch to select Pheonix 3.5 and i have a besttt loader and the relevent up date cy file but could not figure out what settings to apply, Will have another go, Any tips out there? | ||
| elvis, gamma |
