how to clone irdeto v1.2!!!!!!MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Member Join Date: 01-01-2000
the idea is to take your v1.2 irdeto smartcard and duplicate it with a subscribers card. the working card................... read all the data from this card,ascii and hex ser no's,hmk,mkprov00,mkprov10,pmk 00,pmk 10,allpk's prov00,all pk's prov10,and all the channel id's.i use cardblaster 92/93. the 1.2 card....................... kill the card....firecard 146,there should only be an atr on the card and maybe the numbers '20' in other fields. use fmcard 3/4 to write clone crd with the info you took off subscribers card. write the crd to 1.2 card and verify info is ok on card. write the channel id's to the card now. your card should work now!!!!!!!!!!! | ||
| Super Linkerator Join Date: 01-01-2000 Location: Not in UK
It is possible to take an original card and extract the mk's/ppua and then use this info on a gold/fun card to make it autoupdating. Its also possible to add extra providers to an original card.(not a good idea) if you own the card. The problem is you need an original working subscribers card for each provider. why do you want to "kill the card"? nobbly :+ | ||
| The Link Meister | |||
| Honorary Admin Join Date: 01-01-1999 Location: Cloud Cuckoo Land
and if the HMK is made public then the provider can kill the original and all the clones simultaneously too! Playing aroud with MOSCs was great fun in the days before the PIC emulation came along. But you're stuck with a maximum of 2 providers on an Irdeto MOSC, and the MOSCs themselves are (in most parts of the world) significantly harder to come by (and more expensive) than wafers. If you have the HMK you can always create a fully auto-updating (for that particular provider) wafer with it. 2old | ||
| clone, irdeto, v12 |
Similar Threads | ||||
| read and clone old irdeto cards v1.2 | invator | Irdeto system | 8 | 01-10-2006 05:41 AM |
| Eutelsat satellite WC full channel coverage list | Analoguesat | Jimbo's Football and Sport | 0 | 07-06-2006 11:27 PM |
| Irdeto version 4 ? | TheScOrpiOn | Irdeto system | 11 | 05-12-2004 09:01 AM |
| Irdeto debuts CA module with embedded smart card | net1 | Irdeto system | 0 | 04-02-2004 07:50 PM |
| Can I use Xin1 files on Irdeto CAM? | RyokoFanUK | Cams and decoders General | 0 | 25-08-2003 11:49 PM |
