Funcard problemsMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Guest
Posts: n/a
Hi all, Just got my first funcard after playing with goldcards for quite a while. I'm using an elvis progger, with the funload dos software that came with it. I can program the card no problem with the flash.hex and internal and external eeprom hexe's and everything seems fine, but the card will not work when i put it in my aston 1.5 seca cam (using a strong srt4375 receiver) I got the seca hex from: http://hexkeys.host.sk/seca/secafun.zip It apparently has the october keys added. Could someone perhaps try this file and see if they have any luck with it? or point me in the right direction for a working file with keys? Or is there something i could be doing wrong? i have spent ages looking around the net for information including the funcard.net homepage and i seem to be doing everything right. i have tried the funcard editing program to check the keys are in there but i just get a wrong file format error, and i have tried various funcard files but with no joy. I would most appreciate any help in this matter. Kind regards, Jamie | ||
| Super Linkerator Join Date: 01-01-2000 Location: Not in UK
HI Jamie2001 As we are in November, using November keys, has your hex file got the November keys included? It could be that there is a problem with the way you program your card? Can you read the card information from the Cam Menu options in you reciever? This is to know if the card has been programmed correctly. You can find the manual for your programmer here: http://www.satelliteonline.net/images/manual.zip You should try more than one Funcard hex file. Try http://phillsfiles.ubb.cc/ in the Seca section http://www.x-sat.de5.de/ in the funcard secion http://more.at/duck/ click on files optis "4" section funcard http://www.secasat.da.ru/ http://www.irdeto-seca.net/ nobbly :+ | ||
| The Link Meister | |||
| funcard, problems |
Similar Threads | ||||
| Samsung DSR9500 - Not recognizing Funcard | jchurch | Cards & Programmers General | 14 | 07-11-2004 03:44 PM |
| Sky+ recording problems | pjb | Sky+ (Plus) and PVR Systems | 4 | 17-06-2004 11:46 AM |
| Tequilla problems on 30W | dkenny | Adult satellite channels | 0 | 31-12-2003 09:20 PM |
| Few people seek help for sex problems | net1 | The Meeting Place | 0 | 22-08-2003 08:11 PM |
| Problems... Help ! | iwearflares | Analogue systems | 2 | 11-08-2003 08:01 AM |
