Millenium versus Elvis versus VXMultiMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Guest
Posts: n/a
Programmers, programmers, programmers........... Which one is it to be? That is the one million dollar question. Okay........ my requirements are pretty simple: i just want to program a seca card for Tequilla, Palco and the K channels etc. Then maybe try my hand at others like Viaccess. So which programmer is the one for me? Any ideas? I am obviously new to this "stuff" so i need a programmer that is relatively easy to use. Would the Millenium one be a difficult starting position? Would i be better off buying a more expensive one like the VXMulti that could be alot easier to use? I have browsed a few websites for codes etc. Phills sat files seems a good one. So if i want to program a seca card (for tequilla etc) do i just download the appropriate file "Aston 1.03 file by Strsh with Nov keys"? Will this sort out both the EEPROM, and software files? Am i correct in thinking then all i have to do is to load the downloaded files into my programmer and fire it onto the gold card? - God is that all i have to do It seems so complicated.Hope to hear some more advice soon Gaz | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. |
I have found the millenium very easy to use once explained, haven't used the Elvis, but the software seems pretty straightforward also. The VX is probably a sledge hammer to crack a nut. Rolf | ||
| Regular Member Join Date: 01-01-2000 Location: uh::
Hi, The Elvis is as easy to use as the millenium, the only advantage the millenium has over the Elvis is the software is Window base. I first bought a Millenium myself, however with the advent of funcards and Silvercard I had to buy an elvis, because the millenium couldn't program those cards, I haven't use a VXMulti, so can advice.However a survey was done recently and the elvis came out on top. Regards Prince | ||
| ua:: | |||
| elvis, millenium, versus, vxmulti |
Similar Threads | ||||
| what software do you recomend for a elvis programmer? | tipsygent | Cards & Programmers General | 8 | 29-01-2004 12:59 AM |
| firmware for my elvis programmer | tipsygent | Cards & Programmers General | 3 | 24-01-2004 08:23 PM |
| Millenium II upgrade ? | MasterAbacus | Cards & Programmers General | 0 | 01-10-2003 02:02 PM |
| How to use Elvis programmer. | T24 | Tutorials & How To guides | 0 | 21-08-2003 10:17 PM |
| millenium | daddy | Cards & Programmers General | 2 | 01-08-2003 09:58 PM |
