titanium card help!MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Member Join Date: 16-05-2004
| hi, i am new to this satellite stuff so need quite a bit support. I have a manhatton 5900 with U-CAS Embedded penta 1.09. I have a usb/pheonix card reader and a blue titanium card running OS 1.06. I have programmed it using tmb but when the card is inserted in the reciever it says 'no card inserted.' Please help and advise me what i'm doing wrong. | ||
| Specialist Contributor Join Date: 23-08-2003 Location: canaries
| hi yesdan007. i had the same problem with my tit card and tmb in penta 1.09. but when i tried the s**a2 file for s*y it worked fine. i donŽt know why it didŽnt work with tmb, but it did say in the text file it might not. hope this helps you. rob43 btw welcome aboard! | ||
| hi yesdan007. look in www.phillsatfiles.com youŽll also see more links in nobblys big links in the forum jump below, but its the best iŽve seen so far. dont worry about being a newbie, about 10 months ago i was in the same position. and i have only just started to learn. you come on for some info and get hooked. rob43 | ||
| | #6 | ||
| thanks for ur replies guys. I've tried to put the card in every single way possible, but i would assume the correct way so that the chip is facing up. rob43 can u please verify that these files r called 's**a2 file and s*y' or is this just the abreviation. If so can u tell me the full and proper name of these files so can download from the site u gave me. thanks again. | ||
| | #9 | |||
| Irish Mod Join Date: 30-09-2002 Location: Ireland
And then one day you log on only to find you have been branded SLEEPY and your name turned GREEN. Just when you thought you where getting somewhere. | |||
| Don't mind my spelling | ||||
| | #10 | ||
| Thanks again guys for ur replies, i got it working. What i need to know now is my dish is pointing to Hotbird 13' East how do i get to watch all the channels on there e.g. Seca1 & 2, Irdeto 1 & 2, Viaccess etc. Do i need another card e.g. funcard or is the titanium sufficient. Cheers. | ||
| | #11 | |||
| | #12 | ||
| Hi, My dish is pointing to Hotbird 13' East how do i get to watch all the channels on there e.g. Seca 1 & 2, Irdeto 1 & 2, Viaccess etc. Do i need another card e.g. funcard or is the titanium sufficient. Cheers. | ||
| | #13 | ||
| hi yesdan007. a funcard with a 6 x 1 file will open quite a lot of channels. while the tit will open some others. it just depends on the cam and whats available to view. rob43 | ||
| card, titanium |
Similar Threads | ||||
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| UPC Direct and DigiTurk on Titanium card | net1 | Conax, Cryptoworks, Nagravision, NDS and Others | 15 | 16-03-2005 01:34 PM |
| Need Help for program Titanium Card by WinExplorer | coconut | Cards & Programmers General | 6 | 02-02-2005 06:02 PM |
| hang on " sending TRAPCODE" and a new titanium card | hfathollahi | Cards & Programmers General | 22 | 18-12-2004 08:00 AM |
| why wont my elvis programmer recognise my titanium card | tipsygent | Cards & Programmers General | 11 | 07-02-2004 06:48 PM |
