sending trapcode error - blue titaniumMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Member Join Date: 28-05-2004
I read all information here and in other forums concerning the problems erasing the blue titanium card (trapcode error). I tried to follow the suggestions but couldn’t get past “sending trapkey” while erasing the card with Titanium Card Progger V1.10.0. I’m on XP-home 2GHz Intel Pentium 4 using a masterCRD3 programmer in mode1 (Mouse 3.58 MHz). The programmer is powered by an external +9V supply, the titanium has been tested again by the dealer and is ok. I found the following suggestions and tried them all: - disable FIFO buffer for COM - open other applications like Winword, Excel, Outlook etc - press CTRL-ALT-DEL a few times to awake Card Progger - connect to the internet while Card Progger is sending trapkey - disconnect and again connect the serial cable a few times - try to run the programmer in mode 8 (Phoenix 3.58 MHz) - open Explorer and try a large search for files while Card Progger is sending trapkey - clean the contacts of the card Now there are no more ideas left on my side L Any advice would be much appreciated. At least this is a summary of opportunities to get past the trapcode error on a blue titanium. It didn’t work for me but maybe it’s helpful for others. If anyone has any new suggestions please add it here so others may benefit. thx r4lph BTW: all this is not my work, I just collected it | ||
| Irish Mod Join Date: 30-09-2002 Location: Ireland
| On this site you will fine earlier versions of Tit programmer , V 1.7 , 1.9, and 1.8 you could one of these. I use 1.8.1 and find it works best , it may hang for some time but works for me. | ||
| Don't mind my spelling | |||
| @razor thx for that advise. I actually tried Card Progger from V1.5 up to V1.10.2 without any success. Card Progger is using my CPU's bandwith to 100% all the time while erase is started. Is that normal? regards r4lph | ||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I think we may have that in the utilities and downloads section, it is the one by TJ. | ||
| | #7 | ||
| Specialist Contributor Join Date: 05-04-2004 Location: Manchester, UK
| Go to Start; right click My Computer then Properties, click the Hardware tab then Device Manager. Expand Ports (COM & LPT) on the tree; right click the Com port you are using, then Properties, Port Settings and click on Advanced - then you'll see the option - thanks Bill Gates for making windows so easy! | ||
| | #8 | ||
| @guiri thx for the suggestion. I gave it a try with TMB 1.8.3 and it came up with the message "No CARD !!!" after I pressed ERASE TC. I double-checked it with another titanium, same result. Both of the cards tested by the dealer to be ok. thx neway r4lph | ||
| | #12 | ||
| If you are not getting an ATR, it means that either the cards are stuffed or something is already programmed on the card. When the dealer tested them, did he erase them and leave an ATR on the card? It could be that your programmer is faulty? I just re-read your post as well. You'll definitely want phoenix mode on your programmer. Regards | ||
| | #13 | ||
| When I connect to the programmer with Titanium Card Progger I got "No ATR ! unsupported Titanium OS found." So I believe there's no ATR. I'm not sure now if my programmer is ok. I do not have any other cards here at the moment to check. thx for the suggestion r4lph | ||
| | #14 | |||
| Regular Member Join Date: 14-02-2003 Location: home
here on this site, just go to this link: http://www.satellites.co.uk/php-bin/...ad.php?t=23946 You have to use a programmer that has a phoenix mode at 3.57 mhz This tj1965 prog automatically erases the card. Try this and your card will probable work. Tj1965 v1.1 is much faster that the titanium v1.10.0/1/2. | |||
| | #15 | ||
| @gjones thx for that advice. I tried to erase my titanium with Titaniumloader from TJ1965 both V1.0 and V1.1 already without success. It displays "Trapping card.." and after about 20 minutes "Trapping card failed." My MasterCRD3 was set to phoenix mode at 3.58MHz and i gave it a second try in mouse mode 3.58 MHz. No luck :-( thx again for trying to help r4lph | ||
| blue, error, sending, titanium, trapcode |
Similar Threads | ||||
| newbie help prog titanium | bobo63 | Cards & Programmers General | 6 | 02-03-2008 08:23 PM |
| UPC Direct and DigiTurk on Titanium card | net1 | Conax, Cryptoworks, Nagravision, NDS and Others | 15 | 16-03-2005 01:34 PM |
| hang on " sending TRAPCODE" and a new titanium card | hfathollahi | Cards & Programmers General | 22 | 18-12-2004 08:00 AM |
| benfits of titanium? | dasteelman | Cards & Programmers General | 2 | 04-03-2004 10:07 PM |
| Titanium progger V.1.71 | T24 | Editors, Utilities and miscellaneous downloads | 0 | 10-07-2003 08:10 PM |
