plz help with tmb editorMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Member Join Date: 21-09-2004
| please help me. when i try to start the tmb editor, an error box appears that says "system error&H8007007E(-2147024770)." what can i do to sort it out? Hope someone can help me. Finnur | ||
| | #2 | |||
| Member Join Date: 05-10-2004
| Try this !! http://www.explore-interactive.com/...O/NOSupport.htm "System Error H8007007E (-2147024770) The specified module could not be found" ved forsøk på utskrift fra PC som kjører Windows XP Denne feilmelding kan oppstå på enkelte PC'er som benytter Windows XP. Feilen skyldes Windows XP. Hvis feilen oppstår gjør følgende : 1) Kopier filen richtx32.ocx fra rotkatalogen på Explore Interactive CD til C:\Windows\System32 katalogen på din PC. 2) Klikk på "Start"-knappen i Microsoft Windows. 3) Klikk på "Run". 4) I boksen som kommer opp skriv inn følgende : regsvr32 richtx32.ocx 5) Trykk deretter på "OK" knappen. Then do the same with the cx files that comes with TMB,worked for me !! | ||
| Sorry !This was in norwegian ..... Shortly : copy file to C:\windows\system32 ( and the .ocx from TMB) then "start" on meny then "run" and write in "regsvr32 richtx32.ocx" in the box,press "ok" space between regsvr32 and file xxxx same thing with the 2 .ocx files from TMB. Hope this works !!! | ||
| editor, plz, tmb |
Similar Threads | ||||
| plz i need help | WINXP | Receiver software, international Section | 1 | 12-02-2005 08:41 PM |
| Help for TMB Editor | wedgehog | Cards & Programmers General | 1 | 17-09-2004 10:41 PM |
| TMB Editor 2.2 | rolfw | Editors, Utilities and miscellaneous downloads | 0 | 22-07-2004 11:40 PM |
| PolSat key plz | Nokia9800 | Keys and Key editing | 1 | 24-12-2003 07:23 PM |
| Nokia 9650S channel editor | marmal | Cams and decoders General | 0 | 22-08-2003 11:43 AM |
