cardmaster problems
Old 02-10-2004   #1
cardmaster problems
hi im new, both to this board and to programming and im having a little trouble.
i have here what i believe to be a millenium programmer (possibly a 4 quite compact, serial version) and am using cardmaster3 software for the job. trying to write a goldcard. problem is that i sellect the pic and eeprom files and then sellect (auto)write. at the end of programming i get an error after the verifying. it comes up with "failed to write card". if i manually verify the eeprom it comes up with "eeprom verified with errors" anyone got any ideas. searching the web came up with nothing so far. also at what voltage should the writer be running at?? any assistance would be most appreciated. as i say im VERY new to this
thanks in advance
tony2004 is offline   Reply With Quote
Old 06-10-2004   #2
stevo's Avatar
My System: humax 5300 VACI humax f1 vaci *sat 6000 fta patched pixx adt1200 fta infinity usb phoenix cardmaster v 1.0 cas 2 interface matrix revelotion matrix reloaded mii card fun cards gold cards 1 metre dish technomate h to h motor
i got the same trouble m8y mines not writing eprom,not alot known about these,found somthing on www.duwgati.com/uk but not much.
stevo is offline   Reply With Quote
Old 07-10-2004   #3
stevo's Avatar
Smile mines working fine now m8y
mine is the card master 1.0 it runs on twelve volts from my little powerpack,if its the same its got a box on the bottom left it should say card readyin green i think,right ur ready to go.click on the yellow file on the file to pic find file put it in,then click on the yellow file file to eprom put that file in,now erase,pic or eprom click on eprom,a warning will come up about the pic being erased as well,click yes then go to edit or auto program might not be in the same place,then information box comes up wiyh card successfully written,push ok and thats it.have got some files for goldcard if you want them pm me.hope that helps stevo
Old 07-10-2004   #4
unfortunatly im still no better off, turned my voltage up but that makes no difference. ive no problems getting the files i just cant write them. just constant verify failures. doing my nut. it would be a bonus if the software acctually gave you some idea why it failed. is there any different software i can use? i have a feeling it would still fail anyway. thanks anyway
Old 08-10-2004   #5
stevo's Avatar
tony maybe your files are no good where do u get them?your software or loader should be ok. i think my programmer is ancient..
Old 09-10-2004   #6
ive been getting files from europasat. ive got an other writer but never got that going, il give it another shot tho. the newer one is my uncles old one and he used it for ages with no problems.
Old 09-10-2004   #7
stevo's Avatar
theres a couple of files on toecutters as well m8 you wanna try.
cardmaster, problems
Similar Threads
Sky+ recording problems pjb Sky+ (Plus) and PVR Systems 4 17-06-2004 11:46 AM
Problems.... ZeeJay Magic Module 19 22-02-2004 01:27 AM
Problems with 30W Nagra? rolfw Matrix Reloaded, Revolutions and CAS interface 0 29-09-2003 12:01 PM
Few people seek help for sex problems net1 The Meeting Place 0 22-08-2003 08:11 PM
Problems... Help ! iwearflares Analogue systems 2 11-08-2003 08:01 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
