Dragon and Card
Old 14-12-2004   #1
Gladiator8387's Avatar
Dragon and Card
My receiver doesn't have a slot for cards... it only has two slots for cams..
My question is whether a titanium (or any) card can work with a dragon cam...
I purchased a dragon cam.. and i want to know if i buy a tit (or an opos) card will work..
Technosat 9800CIP Omega, Magic Cam, Dragon Cam, Cas Interface, Infinity USB Phoenix, Funcard 6, Irdeto Freecam
Gladiator8387 is offline   Reply With Quote
Old 14-12-2004   #2
ive used a tit card with my dragon cam only when the software is not out first for the dragon
shwonk is offline   Reply With Quote
Old 14-12-2004   #3
Well the idea is that with the latest .dra file loaded into the Dragon Cam, it opens anything currently available (hacked !) without the need for any cards.
I tried a Tit Card in my Dragon but it wouldn't clear Conax on 1w but then a new 2.31 .dra file was posted on Fookfiles and 1w cleared ok without the need for the Tit Card anyway.
24seven is offline   Reply With Quote
Old 14-12-2004   #4
Shwonk - Did you try the latest Conax Tit file and clear 1w with it before the latest .dra release ?
I tried OS 1.06 & 1.03 but got message Smartcard is Conax....... Decoding Failure in the Dragon Cam menu.
Old 15-12-2004   #5
waz
hi,
i would wait a few days as regards the opus. if you are wanting 1w then the MII is usually the 1st to clear,whereas the dragon might take 4days.Yes the MII works in the dragon....approx £24
waz
waz is offline   Reply With Quote
Old 15-12-2004   #6
The Dragon CAM does not support Conex cards. I wish it did as usually tit files are available before a new dragon file.
Grayarea is offline   Reply With Quote
card, dragon
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
