programming cards using a vxmultiMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Have a look at This Thread radioscanner, it should answer your question. | ||
| Regular Member Join Date: 01-01-2000
| THANKS FOR THAT ROLF, The eprom seams to program OK... but I get an error when I program the pic ? (loader failed card faullty) ...I tried several diferent cards and they are all the same. I tried the link to maxking but it doesnt work? http://www.maxking.com/vxmulti.htm#howtousethevxmulti I spent hours looking on the net and I cant find any info on using the vxmulti ? strange! also I would like to program a fun card. hope you can help.-) radioscanner | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Are you selecting both files and then pressing the program button radioscanner? Which files are you using ? | ||
| | #5 | ||
| I have tried the seca files on tonydoe website - http://www.digigate.net/tonydoe/Files.htm I am loading the pic file into the code tab and the eprom file into the eprom tab then pressing the program button on position 8 then I program the pic on position 1. this is when I get the error? thanks | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Unfortunately radioscanner, i don't have one of these programmers, but I don't believe that you should bepressing the program button more than once. | ||
| | #8 | ||
| Super Moderator Join Date: 01-01-2000 Location: Essex
My System: Echostar AD3600IPVA Channel Master 1.2M VxMulti, MM1.04 | radioscanner, I have a VxMulti and am running the VxCardmaster S/W with it i.e. I have upgraded the Eprom to be able to run the new software. This enables me to program all of the card types, including Fun cards. If this is what you have then reply and I'll try to help. Tirosh. | ||
| | #9 | ||
| Hi Tirosh, Surely I should be able to program cards without upgrading my programmer, I bought it ready to program both gold and fun cards... I have tried the vxmulti sw and also chip-cat sw but non of them come with any instructions ..... its amazing the programmer doesnt come with any instructions and I cant find any info on the net.! ? I bought it from maxking...but they dont reply to any prog/card tech questions. Any info you have would be highly apreciated. Thanks. Radioscanner. | ||
| | #10 | ||
My System: Echostar AD3600IPVA Channel Master 1.2M VxMulti, MM1.04 | I'll try to explain as much as I know: Original VxMulti - came with VxMulti S/W and could program GoldW cards but not Fun cards. Hence people were using the VxMulti S/W for GoldW cards and other programs such as ChipCat for Fun cards. If my memory serves me right GW cards were programmed with VxMilti S/W by using mode 8 and mode 1. Then the manufacturers brought out new versions of the VxMulti and also upgrade packages for exsiting users, which consisted of an Eprom and new S/W called VxCardmaster. The beauty of this new S/W is that you can program any card you like by just using Mode 7. You can find more info on the VxMulti web site VxMulti Also, a very useful sounrce of info is the Dugwati site. Hope this helps. Tirosh. | ||
| | #11 | ||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Hi Radioscanner Two models by Vxtools are the multi and the Vx 4 fun. The 'non-updated' multi programs cards in modes 1-6 (whereas atmel cards (fun) are mode 7). The Vx 4 fun programs mode 7 atmel cards. The upgrade to the multi (cost £14) brings it up to the level of the Vx 4 fun and, therefore, able to program fun cards. These 2 links may help you http://www.satonline.co.uk/CARDMANIA/programmers.htm http://www.ecscards.co.uk/catalog.htm Jimbo | ||
| | #13 | |||
| Member Join Date: 11-01-2003 Location: Cumbria
To program a Gold card with VXmulti use mode 2 for the pic and mode 1 for the eep. For a funCard use mode 4 for flash and mode 0 for the eep, I use IC prog 1.05 for the Gold card, and ChipCat for the FunCard. | |||
| | #14 | ||
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | That's interesting G55. Does that sequence work on both the 'Multi' and the 'Multi Pro'? Jimbo | ||
| | #16 | ||
| In the end I did it using chip-cat 3.0 for XP... I set it to 6mhz.. it programs gold and fun cards easy. so I sent for the lousy upgrade for nothing! so what else will I gain with the vxmulti upgrade ? radioscanner. | ||
| | #17 | ||
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Which VX model did you purchase in the first place? Jimbo | ||
| | #19 | ||
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Hi Radioscanner As I understand it and have read, the original Multi (version 1) would not program atmel chips without the upgrade to the version 2 types or the Vx 4 fun. I also saw yesterday that the supplied software tends to make cards unreliable and that's why chip-cat is better. If you get it up to the level of the Multi Pro, I believe you can copy unprotected cards without using a PC. Also it can program Atmel chips other than AT90S8515's. Personally, I believe the best programmer is the 'Elvis' using Multiprog by TJ. It's uncomplicated, fast and reliable and works off a 9volt battery, saving on a DC power connector. | ||
| | #20 | |||
Tirosh. | |||
| | #21 | ||
| Well, one good thing.... I will be able to use the VxCardmaster software when I get the upgrade. I will post a report when I have tested it. thanks again to everyone. radioscanner. p.s. whats the best website for codes? | ||
| | #22 | ||
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | This is excellent here Thanks Tirosh, I suppose whatever works well is good. Interesting subject programming because there's nothing totally definitive about it. | ||
| | #23 | ||
| Member Join Date: 10-12-2002 Location: bedford.england
| re vxmulti. first tab fuses and use radio buttons to click on xt (external) & unprotected. Then tab eeprom & click on the second text icon beneath edit. this brings up the saved hex files. first program the eeprom file then click again on the text icon beneath edit and program the pic file. All this is done having first set the VxMulti on 8. I use the software that came with the VxM. There is a window at the top right which shows you the pic & eeprom combination. hope I am not too late with the posting. | ||
| | #24 | ||
| Its never too late...... Anyway... I got the upgrade for my vxmulti yesterday so now I just use mode 7 for all types of card, it also now works with vxcardmaster software...well worth the 14 pounds. radioscanner. | ||
| | #25 | |||
Tirosh. | |||
| cards, programming, vxmulti |
Similar Threads | ||||
| Blocker for Viaccess PC2.X cards | net1 | Viaccess | 4 | 26-03-2004 04:24 AM |
| Pre-paid cards for Cyfra+ | net1 | Cards & Programmers General | 0 | 22-10-2003 06:30 PM |
| FTV cards switching off | Zorba | Sky Digital (BSkyB) and Astra 28.2 East General | 50 | 12-10-2003 10:43 PM |
| How to/FAQ: programming wafer cards | 2old4this | Tutorials & How To guides | 0 | 15-04-2003 02:34 PM |
| I need your help for program my GOLD card | wahabone | Cards & Programmers General | 6 | 07-06-2002 12:29 AM |
