Infinity USB Question
MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them
Old 17-02-2003   #1
Shaun's Avatar
When I program a Fun4Card I always have to program both the Flash and the Ext EEprom, even though the Flash has been programmed previously. Is there any way I can stop the Flash from being erased so that I only need to update the Ext EEprom?
Many thanks.
Keep the faith,
Shaun.
Shaun is offline   Reply With Quote
Old 18-02-2003   #2
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Unfortunately Shaun, expertise on the Infinity in this forum is a bit sparse. You could post on this link and maybe get an answer there.
Best of luck
Jimbo
jimbo is offline   Reply With Quote
Old 19-02-2003   #3
Shaun's Avatar
Thanks Jimbo, I did post on the forum you mentioned but failed to get a resposne. I now think the issue is more related to the Fun4Card in that a loader probably has to be downloaded to the FLASH in order to write to the Ext EEPROM and this loader erases the FLASH. If there are some programmers that preserve the contents of the FLASH, then I would imagine they do this by reading the FLASH prior to updaing the Ext EEPROM and re-instating it afterwards.
Keep the faith,
Shaun.
Old 04-03-2003   #4
select the write button and select ext eeprom and update the eeprom only!!
Dodddle
Steve
ua::
stevio is offline   Reply With Quote
Old 20-03-2003   #5
Shaun's Avatar
This doesn't work for me, the FLASH ends up getting corrupted. It is however possible to write to the FLASH without corrupting the Ext EEPROM.
Keep the faith,
Shaun.
Old 30-03-2003   #6
Shaun's Avatar
It seems this problem has now been fixed in the lastest release of Infinity-USB firmware.
Keep the faith,
Shaun.
Old 14-02-2006   #7
My System: private
I am a complete beginner with an Infinity USB Phoenix card programmer. Where/how do I find the HEX (?) files to load on to a titanium card for satellite tv use?? Help! Curler
curler is offline   Reply With Quote
Old 14-02-2006   #8
Hi curler,
it would have been better to start a new thread as this thread is from 2003.
To program a Titanium card, using an Infinity/Phoenix programmer, you need it to be connected using both a USB cable and a Serial cable. If this is done you then start your programmer and switch it into Phoenix mode 3.58 Mhz.
You now need the Titanium loader software to be opened, which loader you use depends on which file you want to load, and how to load it can usually be found in the read me or how to file, also you can read lots of information in the Titanium card section:
http://www.satellites.co.uk/php-bin/...splay.php?f=80
There are lots of places to obtain files including:
_http://www.sat-key.org/
Have a read through the Titanium card section and if you have any more questions please start a new thread.
Best wishes
Mickha
Mickha is online now   Reply With Quote
infinity, question, usb
Similar Threads
New soft ware for Infinity usb Programmer. rabbi Cards & Programmers General 1 07-09-2004 01:05 AM
infinity usb pheonix and titanium fasta Cards & Programmers General 3 24-02-2004 12:21 AM
ican someone give me instruction.problem with infinity usb phoenix fotisbak Cards & Programmers General 2 17-02-2004 11:43 AM
How to use Infinity USB programmer. T24 Tutorials & How To guides 1 10-10-2003 07:51 PM
Infinity USB software T24 Editors, Utilities and miscellaneous downloads 0 28-06-2003 12:52 AM
