who can give a Idiots guide to programming dragon
MOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them
Old 16-02-2005   #1
My System: 1.2Cm dish, Motorized, TM1500CI+,dragon cam,SS2....
Unhappy who can give a Idiots guide to programming dragon
i am real newbie, i've tried to search the information from google and here
but still confused.
now i got a Dynamite programmer(usb cable& serial cable) and a dragon cam(vz original loader card, card is empty) and predator file,
then what shall i do next?
just connect both USB and serial cable to the programmer(so it is working @ 6M?), insert the loader card and write the predator file in, that's all?
or anything else i should do?
thanks in advance
coloureye is offline   Reply With Quote
Old 16-02-2005   #2
Hi coloureye,
in the Predator folder you will find a file howto.txt which gives step by step instructions, it is best to print out the instructions and follow them to prevent damaging your Cam.
Please post back if you have any problems.
Best wishes
Mickha
"You need:
-Smartmouse compatible card programmer
-The dragonload.exe program
-Connect the card programmer to com1 or com2, make sure the programmer is in 6 MHz mode
-Execute "dragonload.exe"
-By pressing the "Settings" button, you can change from com1 to com2
-Press "Connect"
-In the file open dialog that appears, select the firmware you want to load.
-The card will now be loaded.
ALTERNATIVE METHOD
For this method, you need a FUN7 card
Using a suitable program, program the FLASH of the FUN7 card with FUN7LDR.HEX,
and program the EEPROM with predator2XX.bin. Make sure the program you use
handle the large eeprom size of the fun7 card correctly!
END alternative method
Insert the programmed card into the Dragon module. Insert this into a receiver
and turn on the receiver. make sure you are tuned to an FTA channel.
Go to the Common interface menu on the receiver, and select the "Dragon Loader" module.
In the next menu, select "yes, Load module".
Now a menu appears indicating that loading is in progress. To see the actual porgress percentage,
select "refresh". There is no auto-refresh because some receivers had problems with that....
When loading is complete, a menu appears saying "Loading successful". REMOVE the loader
card from the module, and switch off and turn back on the receiver."
Mickha is online now   Reply With Quote
Old 16-02-2005   #3
thanks a million, Mickha,
there was no "howto.txt" in the file i downloaded, but i find it,
just tried it, it is working fine, thanks again
all best
CY
dragon, guide, idiots, programming
Similar Threads
Idiot's guide? fredz85 Dreambox General 1 22-08-2005 03:29 PM
An idiots guide to DVB ? Shaygate Satellite PC Card Receivers & Internet by Satellite 11 18-11-2004 11:25 PM
Playboy inks multiple programming deals net1 Daily Satellite and Broadcast industry News 0 05-03-2004 10:32 PM
The Idiots Guide to Satellites waverider The Meeting Place 5 25-11-2003 12:59 AM
How to/FAQ: programming wafer cards 2old4this Tutorials & How To guides 0 15-04-2003 02:34 PM
