Apollo 3 programmer for funcardMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Regular Member Join Date: 05-03-2003 Location: Malaga, Spain
Help needed . If somebody familiar with Apollo 3 programmer, please advise if it is needed to reconfigure paralell port on PC. I am trying different software.Funprom, Funmagic , erasing, alternating between 2 files ( flash and ext.eeprom) and 3 files ( flash,ext and int. eeprom ). All in vain. Nothing but error messages. Looks like my PC and programmer are not communicating. There is no manual and I don.t have a clue how to configur paralell port. Many thanks. Sailor | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | What operating system are you using sailor? | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | There is not much that can be changed with the Printer port, I've just looked in device manager and the only thing that might help is "enable support for Legacy Plug n Play devices", but XP is not particularly friendly to some of this software and hardware. | ||
| | #5 | ||
| It is enabled. does it mean that I am in the dead end. Difficult to accept that I have latest OS , programmer for funcards ,software for this programmer and unable to find a proper guidance how to use them together....Thanks anyways | ||
| Sailor | |||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No. I'm sure that its not the end of the road Sailor, but simply the case that there are not a lot of users of these parallel port programmers, so advice and information is always going to be hard to come by. This is one of the main reasons why when someone asks advice on which programmer, I always steer them towards something like the Elvis, not because its the definitive best, but because there is no shortage of qualified advice available from the many users. I'll keep my eyes open for any information around. | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Just an idea Sailor, can you get access go another PC, perhaps one running W98? Even if you can't get permanent access, at least it would establish whether you are doing things correctly. | ||
| | #9 | ||
| Exellent idea Rolf. I am working on it. Say, I am as new to a computers as to programming ,so this question may look silly, but Can I install Window 98 alongside with my XP on the same PC???? | ||
| Sailor | |||
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yes you can Sailor, but unless you want to format your existing hard drive before doing it and then repartitioning, you would have to add another hard drive. This is exactly what I have done, but have found that I never use the 98se anymore. | ||
| | #11 | ||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | There is of course the utility Partition Magic (version 8) which will create partitions 'on the fly'. If it's possible to use that and load another operating system then a program like ‘BootIT NG’ is useful at handling multi operating systems (free downloads available I believe). Carrying out this sort of thing can be tricky and possibly not the best option for a complete newbie. (No offence sailor). | ||
| | #12 | ||
| Thanks jimbo. No offence taken. True, this procedure with reformating and repartitioning is a bit complicated for me at this junction. I will opt for using friend's PC to check if my problem indeed in OS. Let you know. Thanks guys | ||
| Sailor | |||
| | #13 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I would agree with you Jimbo, its all a lot of messing around, will involve expense and may be troublesome. May be better biting the bullet and buying an Elvis for £50. | ||
| | #15 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Where did you get the Apollo 3 programmer from Sailor? | ||
| | #16 | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Just had alook on the Satarmy.de site Sailor, did you download the drivers as well as the programming software? It doesn't say much about it there, but that could be a problem if you haven't, I would guess that it has to be installed as a new device. Just downloaded the software and under help, it has this info.
| | #17 | ||
| I bought mine in electronic store in Malaga, Spain. You can see them online http://www.electronicasuiza.com/text...trada_old.html When site opens, click Programadores on the left side. If your Spanish better then mine you can also read http://www.zackyfiles.com There you need to click on Grabadores also on the left side. At least in something they are consistant. Have fun. P.S. somehow in preview pane url for Electronica Suiza is correct, but on board copy some simbols are missing.. I am trying to edit it and again it opens in correct version. Here it is again: http://www.electronicasuiza.com/text...trada_old.html | ||
| Sailor Last edited by sailor; 11-04-2003 at 11:50 PM. | |||
| | #18 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Have you tried the emulation mode, in the properties menu Sailor? | ||
| | #19 | ||
| I am not exactly sure Rolf how to handle emulation ? There is something strange with board. I twise corrected internet address and then both times final copy missing some letters within address. It shoud read .......textos/es_entrada...., not ...textos...ntrada.... | ||
| Sailor | |||
| | #20 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | The link works fine sailor, the forum software just shortens it for the visual.. To emulate an earlier version of windows, you must go to the original EXE file of the Fun programmer, right click on it and click on properties from the menu, select Comatability from the top of the panel and then tick the compatability box and select windows 98 in the drop down menu. The program may well run properly. I don't think it will run under XP without that option and even that is not guaranteed. | ||
| | #22 | ||
Thank you all brilliant and talented people. Finally my Apollo 3 cooperated. The problem was as usual simple misunderstanding. This programmer has two ports. One IN female and one OUT male for 2 printer cables. One from PC to programmer and another form programmer to printer. Go figure... I was simply disconnecting printer and connecting programmer, leaving another end open . The rational was that programmer without on/off switch better not be left sitting between PC and printer almost permanently Appearently it is not what manufacturers had in mind. As soon as I used extra parallel female end to plug other end of programmer it started to funcion OK. I only wish they bothered to print simple instruction it would have saved many people many hours. | ||
| Sailor | |||
| | #23 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | LOL, its very often something very simple Sailor, I've been caught many a time by these little things ![]() The good thing is that you have it working and will from this day, be the acknowledged authority on the Apollo 3 | ||
| | #24 | ||
| "Aknowledged authority" is huge overstatement but thanks anyways. Now I have bigger challange. To learn how best use my Samsung 9000, my Aston cam and my Apollo 3 to get more signals of more providers in more encodings on my screen. So I would have to read all you smarter guys posted on forums. If only my brain was some 40 years younger... | ||
| Sailor | |||
| | #25 | |||
| Member Join Date: 05-04-2005
My System: apollo programmer |
| apollo, funcard, programmer |
Similar Threads | ||||
| Multi-Yo! programmer +Tit card how to?!! | hellpic | Conax, Cryptoworks, Nagravision, NDS and Others | 4 | 26-09-2004 01:21 AM |
| Madonna programmer & Cardwriter s/w | smudger_smith | Cards & Programmers General | 3 | 15-09-2004 10:45 PM |
| why wont my elvis programmer recognise my titanium card | tipsygent | Cards & Programmers General | 11 | 07-02-2004 06:48 PM |
| magic cam programmer | richardp | Cards & Programmers General | 1 | 02-12-2003 07:28 PM |
| How to use Infinity USB programmer. | T24 | Tutorials & How To guides | 1 | 10-10-2003 07:51 PM |
