what channelsMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Guest
Posts: n/a
hi there can anyone tell me when downloading files to programme is there anyway in finding out what channels you will get out of the files you download . also when i download a file i get several files in my documents which one is the one i need to put on my programmer to programme my card . thanks derek | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Unfortunately Derek, unless the file tells you in it's readme, you have to check what's available by going to www.lyngsat.com or www.satcodx.com and looking for channels which are encrypted in the relevant version, ie, if its a Seca file, you should be looking for mediaguard (not M 2). If its a 6-in-1 file then obviosly you have more to look for, but quite often there will be a readme with details of providers covered by the file. With regard to which files to use, normally there will be some hint, it may be in the readme, it may be in the file name, ie Humax or Freecam etc, or it may simply be the latest one for the Eeprom. | ||
| Honorary Admin Join Date: 01-01-1999 Location: Cloud Cuckoo Land
| if you view the file that contains the keys and provider information ("idents") using the correct editor (an editor that can correctly interpret the particular layout of the key-file) then you will be able to read out the provider idents and the keys. This will allow you to determine which providers (i.e. packages) are enabled, and (by reference to an up-to-date key site) whether the respective providers' keys are actually active. Reference to a site such as Lyngsat will then show you which channels are available for those providers. 2old | ||
| Guest
Posts: n/a
hi rolf tried 2 or three times to programme the gold card but up till now had no joy . on my programmer in the pic memory i put the following seca16provamei.2003 in the external ee prom there is nothing in the card i put gold in the pic i put 16f84\a in the ext ee i put 24c16 can you think what i am doing wrong . thanks derek | ||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | After you have loaded the files and pressed programme. what messages do you get at the bottom of panel? | ||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | In the three right hand boxes you should have: Gold Card 16F84 24C16 In the three lefthand boxes: Tick and load Pic File Tick and load Eeprom Code protect off | ||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | If you've unpacked the zip file to your documents folder you will find the two files, they will both end in .hex. | ||
| channels |
Similar Threads | ||||
| Indian DTH: Dish/TataSky/DDDirect+ (All Info) V2 | Analoguesat | Dedicated DTH (India and Region) | 706 | 05-09-2006 12:25 PM |
| Indian DTH: Dish/TataSky/DDDirect+ (All Info) | URPradhan | Dedicated DTH (India and Region) | 634 | 04-08-2006 10:09 AM |
| English Audio on satellite channels | cowboy | Transponders & channels | 11 | 23-02-2006 01:08 AM |
| New RAI channels | net1 | Transponders & channels | 1 | 05-01-2004 04:42 PM |
| BBC Channels | pedrolopes | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 1 | 10-07-2003 03:13 PM |
