Samsung DSR9500 - Not recognizing FuncardMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Member Join Date: 27-06-2003
| Hi , I`ve just become a member on the forum and have just acquired a USB Infinity programmer with Fun card 5. I was hoping that some of you clever guys out there could help me out with a problem I`ve got. I have a Samsung 9500 VIA CI which I`ve patched with software version 118 giving the 5 in 1 patch. I`ve managed to program the funcard OK to get ABSAT channels using the file `2ndfun5in1v1.20_Jula_AU_18.06.2003.` After unzipping , this comes with a flash.hex file , `eprom_integral.hex` file and a `eprom_by_jula.hex` file. All these load into the funcard5 via the Infinity USB programmer with no problem. After I insert the card in the Samsung9500 it recognises the card as a Mediaguard card OK. My problem is when I try using a different 6in1 file. I downloaded the file off Phillsfiles.com. It is called `davem_fun_6in1_030703.zip`. After unzipping it it and reading the readme.txt it looked like the files should work with a Samsung9500. The files that I loaded onto the funcard5 were : `flash_6in1_v4.3.hex` into the flash area of the card. `eeprom_H_030703.hex` into the external eprom area of the card I left the internal eeprom area blank. Unfortunately the Samsung does not recognize the card and when I go into the card information menu on the Samsung whereas it said mediaguard on the `2ndfun5in1v1.20_Jula_AU_18.06.2003.` files it now says `no card` with the davem_fun_6in1_030703 files Does anybody know why the samsung is not recognising the card. Do I need a different type of card - eg Gold or silver ? Do I need a different CAM.Eg Irdeto - as I understand that a lot of the 5 in 1 files operate via irdeto somehow. I was under the impression that the 5in1 patch allowed the Samsung to recognise : Viaaccess ,conax , Seca Mediaguard , Nagro. I`m not sure if it does the irdeto. Does anybody know ? Any help would be most appreciated. Its all a bit confusing at the moment but I hope to get my head around it in the next couple of weeks. Thanks in advance for any help. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Although I have no experience with the patched Sammy, is there a CAM menu in which you can select different modes for the CAM, it certainly sounds as if you have used the correct procedure with the Dave M files, but may also be worth trying the Xamuh files, they are set up specifically for the Sammy. | ||
| Regular Member Join Date: 03-01-2003 Location: tyne and wear
| hi jchurch the answer to your question has already been answered look at receiver upgrades and a post by steve102 remember reading past posts can be a hive of information some of it good some of it not so good. | ||
| | #9 | ||
| Info Exec Join Date: 09-10-2002
| Yes,your samsung can decrypt Viaccess channels.if your samsung is patched it can decrypt alot of channels.(load your receiver with samsung EMU) or load a silver card with bbaio files (6in1) insert the card into the embedded cam. Ps-insert the card into the embedded cam correctly,the chip downward.. (power OFF/ON) Load the latest via..files works fine on fun card. Good luck Good luck | ||
| | #14 | ||
| Regular Member Join Date: 31-08-2003
| hi i have same problem , the fun card is not recognizing with the receiver , but my receiver is not samsung as every one talking , It is redix dt-43 s vaci software version DT-43S V1.0.00 firmware V1.2.1-1614SA Terminal serial number 34-1-0001469 Viaccess version 1.1 R 484 terminal application 1000.121 so if any one can tell me what should i do, greatful to him | ||
| | #15 | |||
| Member Join Date: 06-11-2004
Thanks, Hormoz | |||
| dsr9500, funcard, recognizing, samsung |
Similar Threads | ||||
| Samsung 9500 EM VIA. | veginfor | Receiver software, international Section | 5 | 2 Weeks Ago 08:11 AM |
| Samsung Dsr9500 Via Ci | richardp | Receiver software, international Section | 3 | 01-04-2005 07:20 AM |
| when i dsr9500 started , it display menu downloading then stopped | omid pirooz | Receiver software, international Section | 2 | 27-07-2004 02:39 PM |
| conax funcard 1 WEST | ceen | Conax, Cryptoworks, Nagravision, NDS and Others | 19 | 14-02-2004 08:25 PM |
