Madonna programmer & Cardwriter s/wMOSCs, DPSCs, (gold)wafers, PCBs/PIC-cards, SMDs, and devices for programming them | |
| Member Join Date: 01-01-2000 Location: West Sussex
| Hi Being a tight-fisted sort, when I was given a Madonna programmer by a good m8, I was reluctant to discard it when I found it wouldn't work reliably with Cardwriter V2.06 These programmers were available from Ma*king several months ago but are not mentioned on their web site now. The programmer works fine with V1.87 - unfortunately V1.87 apparently can only deal with basic FunCards. V1.87 doesn't seem to be able to program external EPROMs greater than 8KB. I needed to load 2 FunCard 4s (32KB) or one FunCard 5 (64KB) to upgrade the f/w in a Joker/BlackIce CAM. I got into the 'Insert Card 1' then 'Insert Card 2' loop which indicates that not all the code is present. I found V2.06 and, strangely, this worked with the programmer just long enough to program my FunCard 5 since when I get a 'Sync error' every time I try and use V2.06 with a FunCard. V1.87 will see the 90S8515 CPU on any of my FunCards without any problem but 2.06 - nah! I suspect that there is a cruital timing margin which V1.87 deals with OK but V2.06 fails to handle consistently. Has anybody come across this problem? If so how did you resolve it? Is there some other s/w which will handle FunCard 4, 5 & 6? Cheers Smudger | ||
| Hi My m8 who gave me the programmer has done some research and has come up with Masterburner V2.3. This does the trick for my FunCard 4s at least. In the configuration section there is a variable delay for the AVR timing which is set to 9mS. I suspect this value may be too small in Cardwriter 2.06. Anyway, I'm now able to program my FunCards again. Cheers Smudger | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Well done Smudger, always good to see someone come up with their own solution and If I might say, even better when they take the time to post and let people know how they did it. | ||
| cardwriter, madonna, programmer, s or w |
Similar Threads | ||||
| Multi-Yo! programmer +Tit card how to?!! | hellpic | Conax, Cryptoworks, Nagravision, NDS and Others | 4 | 26-09-2004 01:21 AM |
| why wont my elvis programmer recognise my titanium card | tipsygent | Cards & Programmers General | 11 | 07-02-2004 06:48 PM |
| firmware for my elvis programmer | tipsygent | Cards & Programmers General | 3 | 24-01-2004 08:23 PM |
| How to use Infinity USB programmer. | T24 | Tutorials & How To guides | 1 | 10-10-2003 07:51 PM |
| Cardwriter 2.06 | jamidonuts | Cards & Programmers General | 1 | 27-09-2003 09:13 AM |
