wiped the int eeprom and flash memory
Old 30-12-2003   #1
today i got an infinity.
on the first attempt i wrongly erased the int eeprom and flash memory.
can i get it back or do i need a new card?
thanks guys
doggy is offline   Reply With Quote
Old 30-12-2003   #2
rolfw's Avatar
Real name: Rolf
My System: Sky+, DB 7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Spectrum analyser.
thanks guys
What card is this on Doggy? If it is a fun card, then all you have to do is program the card with the new file. most fun files only use the Flash memory and external Eeprom.
Rolf
Old 30-12-2003   #3
yes rolf its a funcard 4 or a prussian2
ive tried programming it about a dozen times, still no luck.
im fairly sure im doing it right.
on my first attempt the programmer prompted me to detect the cpu wiping the memory. thats fine, then i wiped it again and check it in the stb. i wasnt getting my channels so i thought all was well. i then programmed the card and checked it in my stb. i was getting all my old channels (tps etc) but not ned 1 2 3, sbs6 yorin,veronica. net 4 5. so i wiped it again and tried to reprogramme again.
since then i cant get any channels except fta.
im programming the flash and ext eeprom with files and advice from a guy on toecutters ( the guy is good so i dont think its him)
everytime i read erase or write the card it reports back done with no errors.
any ideas im starting to panic?
Old 31-12-2003   #4
your tuner may not like the program u use. try another program for fun
info2 is offline   Reply With Quote
Old 31-12-2003   #5
what kind of programme and do you know where its available?
thanks
Old 31-12-2003   #6
Salty Tech Monster Mod
waverider's Avatar
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+
I suspect you may be using a file that is not suited for your receiver m8!...you have an Xtreme dont you?...mine is ok!.....all i do is load card...let Infinity detect....erase old files......then load files to Flash & ExtEEP (I import them from My Documents after extracting from Zip!) then write....I am using the Prussian too!....
waverider is offline   Reply With Quote
Old 31-12-2003   #7
raptors worked first time, well done you saved my bacon. and i got my dutch channels back!
you can be my new best pal
Old 01-01-2004   #8
waverider's Avatar
I know of another good file doggy but because of forum rules i cannot post it on here m8
Old 01-01-2004   #9
pm it to me in here or in toecutters if you can.
do you get the mtv channels? i get french and central, i dont get base, brand new, hits etc?
cheers m8
eeprom, flash, int, memory, wiped
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
