Where do I put the IRD and Boxkey in the Titanium? | |
| Irish Mod Join Date: 30-09-2002 Location: Ireland
| There is no box key or IRD needed for tit card. Just unzip your file and it will contain 2 files HEX + EEP ( some files have 3 HEX + EEP + CRYPT EEP ). On the top of Tit programmer V 1.10.0 you will see 3 boxes...marked load HEX.......load EEP. and load CRYPT EEP. that is all you need. Load the files and click BURN. | ||
| Don't mind my spelling | |||
| Single Join Date: 04-02-2004 Location: North of the Tejo & South of the Thames
My System: Yamaha YZF-R1 | Thanx Razor, I´ve done that. I am getting 30W well with the following exceptions: -The MR freezes every so often but then starts again -With the Titanium programmed as you say it will freeze and sit there eternally. Any advice welcomed Regards, John Equip: Samsung CI-702E Matrix Reloaded 1060 (1070 hangs worse than 1060) | ||
| I have heard that the Tit works best in MM. It will work in MR but some people have the same as you stopping and starting. What OS are you using...103 105 106.... If you are brave try another OS on the Tit. As for me ...I would leave it be and settle for what I have. But then I'm on Conax at 1w and mine works fine...No Stopping and Starting. | ||
| boxkey, ird, titanium |
