Clarke Tech 5000 HD Combo Plus
Section for discussion of Clarke-Tech High Definition receivers
Old 07-01-2009   #1
LAURO2008's Avatar
My System: * Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo Light 2.3 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player *
Thumbs up Clarke Tech 5000 HD Combo Plus
Hello,
Within 2 days I will get my first HD receiver...finally !!!
It will be a CT 5000 HD Combo Plus now I kindly ask you all 3 questions:
-what are your applications with the ethernet connection?
-what are your personal impressions about the receiver?
-what makes you really angry?
Thanks in advance for your feed back
LAURO2008 is offline   Reply With Quote
Old 09-01-2009   #2
My System: HP
Hi friend Lauro2008, sorry for disturbyou, but i the future next I´m looking to get a Clarcke Tech 5000 HDC+ but I miss to know if it is a good choice, because four years ago I´ve got a Humax 2000 hdci, it was a razonable choice, but in softwere progress is very poor, and parching, fixing or openning channels is normally a problem because it dont have same features as many others, so I´m trying to ask as much as I can, to a Clarcke Tech 5000 HDC+ wonners, if they are happy with this reciever, because it can hep me in the decision, because I´m looking as well for a Dreambox 800 HD PVR, but this choice is more expensive...
so if you can give me a word obout this reciever ct 5000 hdc+ and if it works perfetelly with a diablo ligth 2.3, I will apreciate it very much
My thanks and a very happy year 2009.
f.mateus is offline   Reply With Quote
Old 10-01-2009   #3
LAURO2008's Avatar
Bom dia mateus,
Actually I'm also looking for answers about this receivers....
I got it yday, put the latest firmware,softcam,channel-settings and diablo 2.3: simply perfect!
It is too early to write my impressions but what I can tell you is that Clarke Tech owners are fully supported with softwares
If you consider that I still have and I don't want to sell a CT2100plus....
So far so good
Ciao
Old 04-02-2009   #4
LAURO2008's Avatar
I still consider the receiver a great one BUT how I can get some "c/s steps" it is a mistery :-(
Old 23-04-2009   #5
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
I'm also interested in this receiver. As I've understood from russian forums, there's "alternative" firmwares, ending with P letter in name, that support c/s over ethernet.
Anyone tested this receiver with diablo wifi ?
BombedOne is offline   Reply With Quote
Old 24-04-2009   #6
LAURO2008's Avatar
Hello BombedOne,
Is everything OK in Georgia? Probably you know more than me about alternative firmwares.
The receiver is just perfect use it with a Diablo 2.3 (not wifi) but I stopped digging around c/s
Can you, pls, send me the Russian link in PM?
Old 24-04-2009   #7
BombedOne's Avatar
I also ordered this receiver, when it arrives, I'll give you best firmware then, because there are several versions of them, and some need non-standart loading ways.
Old 25-04-2009   #8
LAURO2008's Avatar
Only now I got what you meant by "firmwares with a p at the end"...currently I have 158 (Original) and 162p (Emu). It is 2 months now with the same one ...awaiting for the 163p
Keep you posted
Old 10-07-2009   #9
LAURO2008's Avatar
any news? thanks
for a better
Old 28-08-2009   #10
My System: none yet
hi! can you watch MPEG-2 4:2:2 feeds with Clarke-Tech HD 5000 Combo Plus?
lindeman is offline   Reply With Quote
5000, clarke, combo, tech
