Dual PCI Network card question | |
For the experts I suppose A customer has a PC fed by a broadband connection from his Virgin cable supplier, and is now looking to run one of the *ahem* sharing receivers, which also requires an ethernet port. Rather than go down the route of buying yet another router, would it be possible to fit two PCI cards into the PC, and have it connected that way ? PC is using Win XP o/s and recognises both cards independently when they are wired up to the cable box , I just need to get the second cable, for the receiver if somebody can confirm the PC motherboard will process ethernet from one card to another. Thanks
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | It should work fine, just set up ICS and you're good to go... ![]() Obviously it won't work if the PC is switched off... ![]()
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Internet connection sharing you will find it on the control panel Network connections Local area connection or high speed internet icon right click on properties advanced tab ICS
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
