Booting problemAll of us accessing this forum are using a computer, if you've got a problem, have or need information, then post here. | |
| Member Join Date: 16-10-2008 Location: Spain
My System: 1.9M dish with FTA box. 80CM dish with monoblock pointed at 13 & 19 degrees. Technomate 1500CI |
When I switch on my pc it sometimes lights the green light and no more. I then have to switch it off with the on/off button located at the back of the case and then press the start button again. This time it will boot ok. I have formatted the hd, installed XP, vista and even Linux, but still it persists. Any ideas anyone ????? I was told it could be the power unit on the blink. Phil | ||
Yes I have to agree with them it does sound like the PSU is on its way out, if the interlock does not sense everything is OK it will not allow current to flow and power up the equipment. It is often as a result of too may addon devices exceeding the capabilities of the supply at startup, if every USB device is plugged in when it happens take something out and see if that helps. | ||
My System: 1.9M dish with FTA box. 80CM dish with monoblock pointed at 13 & 19 degrees. Technomate 1500CI | Hi Topper I take it you mean MSCONFIG ... STARTUP .... remove what is not needed. Just done that and will see what happens ... thanks | ||
| Member Join Date: 02-07-2008 Location: egypt
My System: i would like to learn electronics | I think this may help: pulloff ac power cable pull off rams from slots &clean them with dry (soft) thing (to realese dust) fit them again check hdd cable(power&data) cd or dvd cables try starting your pc | ||
| | #5 | ||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | | ||
| | #6 | |||
Thanks CF that is exactly what I mean, I was round at someone's house today and he had 4 USB devices connected all the time an extra HD and 2nd Optical drive. Unless you have a 500w or 600w supply they should be unplugged when not being used...... | |||
| | #7 | ||
My System: 1.9M dish with FTA box. 80CM dish with monoblock pointed at 13 & 19 degrees. Technomate 1500CI | As always, thanks for your speedy replies. I am now in the process of cleaning as advised. | ||
| booting, problem |
