Problems reading a hard disk
All of us accessing this forum are using a computer, if you've got a problem, have or need information, then post here.
Old 06-09-2009   #1
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
My "lovely little lappy - Omnibook 6100" died a few years ago (I really must update my profile). There are some files on the hard disk that I would like to extract but unfortunately I password protected my area in Documents and Settings.
The hard disk is fine and, putting onto an eternal hard disk adaptor I can read all the other sections of the disk but when I try to access my own area it simply say Access Denied. I know the password and would willingly put it in if I were asked!
Any ideas what I should use to access the protected area or remove the protection?
I feel a bit embarassed to post this as I'm supposed to be an IT bod and people come to me with these sort of problems
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 06-09-2009   #2
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
could you add an account to the laptop with previous user name and password?
pgh13 is online now   Reply With Quote
Old 06-09-2009   #3
Amo Amas Amant Admin
Topper's Avatar
Well
The laptop is no more how can he do that?
I am not familiar with the type of password you have set on there Paul and what was the O/S?
If it was Windows 98 then I have an Omnibook xe3 you could drop the drive into it will of course not boot cleanly i.e finding different processors etc but it should be sufficient to remove any password protection, since I suspect that area of the drive will be encrypted now and unless the drive is booted up there will be no way of reading it.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 07-09-2009   #4
PaulR's Avatar
Sorry, hoist by the petard of not providing enough information.
OS is Windows XP, probably only SP2, and the password is the one you have to supply to sign on in XP, not a bios one.
The problem with putting the hard disk into another laptop is that XP doesn't like too many changes in hardware at once. I believe that it will only handle 2 or 3 at time, such as memory increase, hard disk size, motherboard, video chip etc. I have tried this before and it refused to boot.
Old 07-09-2009   #5
Topper's Avatar
Mmm
Well I have done it a couple of times with XP, and I have 3 different lappies to choose from as well. If you want to try let me know, only problem is I am away tomorrow for 10 days.
Show Your Support
Thank you.
Old 07-09-2009   #6
I have never found any problems with the XP password, but then usually I've run the hard drive in safe mode, logged in as administrator, and accessed the files that way.
Or I've run the drive as a slave, in my PC, using an adapter, and had full access, to all the files, using explorer.
Have you tried using Hirens Boot CD? Although as you have the drive fitted externally is it recognized on boot up or does it require drivers in your Windows Operating System?
Have you got a 2.5 to 3.5 adapter? The last one I picked up was less than £1 off Ebay. If so you could try running the laptops hard drive in your PC, and see if you can access the files.
I don't even bother fitting them I just remove the side panel and connect the cables externally.
The one I used was similar to this, but I'm sure your local PC shop should have one.
Problems reading a hard disk-2-5-3-5-adapter-jpg
Mickha is offline   Reply With Quote
Old 07-09-2009   #7
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
If you start your system up in safe mode, navigate to the locked folders (usually your Username), right click on it, select properties, go to the Security tab and then the permissions button, through that you can set the permissions on the passworded folders to be accessible by all, and you're sorted...
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 07-09-2009   #8
You can get a very nifty external drive case for 2.5 drives for about a tenner. They have 2 USB connectors at the host PC to give enough ooomph so you don't need a separate PSU
Old 07-09-2009   #9
Topper's Avatar
Mmmm
But he hasn't got a system....... that is the point lappy is defuncted
To me this from post 1 indicates Paul is already using an external hard drive adaptor
Show Your Support
Thank you.
Old 07-09-2009   #10
2cvbloke's Avatar
Originally Posted by Topper View Post
But he hasn't got a system....... that is the point lappy defunct
I meant on the system being used to access the drive, AKA a PC or another laptop, done it many times myself, both for personal drives and when I was working at the computer shop...
Old 07-09-2009   #11
PaulR's Avatar
Topper is correct, the HD is connected to an external HD adaptor and to my other lappy via the USB.
I've just tried to access the forbidden area and a strange thing has happened. It may have been something I've done with removing the read only tag from the folders or not but I can now access the folders!
It's not all fixed yet though as when i double click on a file it doesn't yet open. The Word files even say that I don't have permission to open them so I've got a bit more work to do yet.
Why it should be changing now when I've been unable to get in before I've no idea!
Old 08-09-2009   #12
Mod and septic resident
Channel Hopper's Avatar
PC Inspector is the software I use to pull anything out of a corrupted drive. I ha a tendency to ignore any password protection.
Old 08-09-2009   #13
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
Did you use encryption?
If so you may have trouble accessing the files.
If the user folder structure was just made private while applying the password, I normally boot a live Linux CD to get around this problem.
Slax is one distro that does this fairly well, i.e I've gotten it to recognise drives that other distros didnt.
compufunk is offline   Reply With Quote
Old 08-09-2009   #14
PaulR's Avatar
No, not encrypted
That's exactly it.
Would that work with disk in question being now an external drive attached via USB?
Besides it's not a question of the drive not being recognised. That was never the problem, it's being able to open the files themselves. I get a warning message saying I don't have access rights.
Old 09-09-2009   #15
Archived Member
Have you tried copying the whole folder to your PC, and then try to open the files from the PC? or you get error message when you try to do this?
HB13DISH is offline   Reply With Quote
Old 09-09-2009   #16
compufunk's Avatar
I cant see why not, I've done it often enough.
I realize it was not a question of the drive being recognized under windows, I only mentioned this because certain disks may not be recognized under certain flavors of linux.
One small thing that may be significant when you are copying the files/folders to a new location. If you can, try to copy to a FAT drive/partition. This might remove certain file attributes that are causing you grief.
Old 10-09-2009   #17
PaulR's Avatar
Already thought of that. Tried copying a file and it won't allow me to.
Old 30-09-2009   #18
PaulR's Avatar
I tried using PC Inspector and it just threw up error after error trying to read the directories, sorry folders.
What I DID find was a free program called DiskInternals NTFS Reader. It worked a treat and I was able to suck all the info I wanted off the disk.
_http://www.diskinternals.com/download.shtml towards the bottom of the page.
There's also a program called Linux Reader which I should be able to use for another problem I have
disk, hard, problems, reading
