Connect using a dial up modem greyed out in XP?!
All of us accessing this forum are using a computer, if you've got a problem, have or need information, then post here.
Old 06-01-2005   #1
Super Minty Mod
PoloMint's Avatar
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections
I'm trying to set up a dial up connection here in case the broadband goes down, but when I try and set up a connection to the internet I am unable to select 'connect using a dial up modem' as it is greyed out:
I've been through the MS knowledge base and usenet groups and the two main causes of this seem to be services not running or missing registry entries – both of these seem to be ok on the system.
What's more the system did have a dial up connection before, when I installed windows about six months ago I put it on, but it is no longer present. It's not my system so I don't know when or why it disappeared, it was never used except to test it.
The system is XP Pro with SP2
The only things I can think of now are system restore, but I've just spent ages setting up scheduled tasks and doing general system tweaking so don't want to have to do that again, or getting a disk from another ISP that comes with it's own dialer and changing that for the ISP we want – telefonicanet. But that's messy and might not work anyway as bits of windows seem to be missing, so I'd rather get them back and set it up properly.
Anyone got any ideas as to how to get dial up connections back?
'All you need is duck tape and WD40; if it moves and it shouldn't, use duck tape - if it should move and it doesn't, use WD40'
PoloMint is offline   Reply With Quote
Old 06-01-2005   #2
w hole's Avatar
Hello PM
Have you checked that your modem is installed correctly.
EITHER
"Control Panel - Phone and Modem Options -"
OR
"Right Click on MY COMPUTER in the Start Menu.
Select PROPERTIES
In Box that opens select DEVICE MANAGER
Open the Section for MODEMS by clicking on th +
Right Click on your Modem and select Properties"
THEN
Choose the Diagnostics Tab and Query Modem.
The response should confirm whether you System is 'seeing' the Modem.
If it is then sorry don't know what else to suggest, but I'm sure someone will.
Kind regards
W. Hole
w hole is offline   Reply With Quote
Old 06-01-2005   #3
Super Minty Mod
PoloMint's Avatar
Thanks for the reply W.H. yes, the modem is installed and recognised correctly. Sorry I should have said that in the original post. It sends and receives faxes and acts as a telephone answering machine. The telephone answering software is disabled when I try and set up the connection so nothing is hogging the modem.
Old 06-01-2005   #4
w hole's Avatar
Hello PM
I'm also on XP Pro and SP2, but my Flash Screen is a bit different :
http://www.satellites.co.uk/php-bin/...tid=1688&stc=1
Don't suppose this helps, but it might give someone a clue
Regards
W. H.
Connect using a dial up modem greyed out in XP?!-my-dial-up-flash-jpg
Old 06-01-2005   #5
BGonaSTICK's Avatar
I seem to remember something similar.
XP is right funny with modems sometimes. I have a feeling that once you get the connection wizard to see the modem correctly, it will give you the option.
I have a LAN connection to my adsl gateway, but a 33.6 3com modem on the 'client' box as backup, and it works OK. I get all the options in the wizard, but I couldn't get it to work with any 3com drivers (don't think I even found any? Supposed to be 'in XP' but could only find generic).
I used the Micro$oft one...
What have you got installed?
Connect using a dial up modem greyed out in XP?!-modemdriver-jpg
Old 06-01-2005   #6
w hole's Avatar
PM
There is a Computer section over at Dudz:
http://www.satdudez-forumz.com/
I have found them very informative in the past.
Regards
W.H.
Old 07-01-2005   #7
Super Minty Mod
PoloMint's Avatar
Thanks for the replies guys, I got it working in the end. A service I thought was running in fact wasn’t.
Someone’s gone mad on the system disabling services, I’ve never seen a system with so many of them turned off.
Old 07-01-2005   #8
BGonaSTICK's Avatar
Which service was it?
Old 07-01-2005   #9
Super Minty Mod
PoloMint's Avatar
It was one, or all of, remote access, connection manager, remote access auto connection manager or telephony. But I don't know which one, I restarted all of them, (they all seemed to be running before) then it stared to work.
Old 21-07-2009   #10
Real name: Ray Bayles
My System: Varies based on service call
Microsoft recommends fixing Telephony... but that is not always the problem. We have some very experienced technicians, and when this problem is discovered, we can seldom make a fix. The time lost trying is very costly.
The solution posted by PoloMint does not often work for us.
Those who have posted should know that ALL normal connections and fixes do not work... as far as detecting... connection wizard... diagnostics tab and query... or device manager... etc suggested above. The modem can be seen. It works. You get the correct responses in the control panel for modem... but the problem is Windows related... all is well until you reach the screen as posted by PostMint on 06/21/2005... to the problem has been going on for four years without anyone posting a reliable solution anywhere we have found.
DryCrick is offline   Reply With Quote
connect, dial, greyed, modem
Similar Threads
Very old dial tuning analogue receivers - any value? Rob Wheeler Analogue systems 15 23-04-2006 10:33 PM
How do I connect DB to the internet via 56k modem to download new image Tore567 Dreambox General 11 02-03-2005 11:14 PM
IDT and Connect Spot launch Simplifi net1 Daily Satellite and Broadcast industry News 0 25-02-2004 08:35 PM
Cable Null Modem sara1970 Receiver software, international Section 1 18-01-2004 06:48 PM
What Modem Pci Card do Netsystems use? Mr G Satellite PC Card Receivers & Internet by Satellite 1 06-12-2003 01:47 AM
