Toshiba satellite pro 6000 fan problemAll of us accessing this forum are using a computer, if you've got a problem, have or need information, then post here. | |
| Specialist Contributor Join Date: 11-08-2004 Location: Belfast
My System: Dreambox 7020S; DBox2 DVB-C; 1.1m Triax twin LNB for Astra & Hotbird; 90cm Sky dish for Hispa; 4-way Diseqc |
Hi mates, My Toshiba satellite pro 6000 "hangs" after 2 hours of continuous use. I removed the keyboard to see the cooler and noticed that the fact is not spinning. I remove the fan plug and applied a 5v power direct to check whether it is not fecked and I was happy that it spinned. I noticed that the Fan spinned once only with the one hour I was observing it (after I have plugged the socket back on the main board). I intend to hard wire the fan to a 5v power point on the mainboard as I feel that the circuit which triggers the fan may be fecked - This would be as a last resort. Any advice will be appreciated. Thanks | ||
| Regular Contributor Join Date: 01-01-2000 Location: essex boy
| yes you can do that if you want, no harm done, the battery wont last more than 10mins with the fan running at full blast, and ohh the noise !!! fan on tosh laptop rarely runs unless you are really working that CPU to death with all that numbers crunching, could be something else hanging it instead | ||
| Start and run the 6000 in safe mode and see if it also crashes in the same sort of time frame. If not , then you should be looking elsewhere for the problem. A number of conflicts can arise with certain wireless network devices, have you tried disconnecting one if you have it ? | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| 6000, fan, pro, problem, satellite, toshiba |
Similar Threads | ||||
| R.R. Satellite Communications Ltd with Viaccess | net1 | Daily Satellite and Broadcast industry News | 2 | 13-03-2009 01:56 AM |
| Digital satellite viewers lose free channels | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 5 | 16-06-2005 01:22 PM |
| Last-minute deal on free-to-air satellite | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 11 | 29-10-2003 11:29 PM |
| Solus Cards | zansi | Sky Digital (BSkyB) and Astra 28.2 East General | 1 | 06-08-2003 01:22 PM |
| Will the BBC's satellite dream ever take off? | net1 | Daily Satellite and Broadcast industry News | 0 | 26-06-2003 08:49 PM |
