Firefox speed up procedureAll of us accessing this forum are using a computer, if you've got a problem, have or need information, then post here. | |
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. |
I know that Marts posted this a year or so ago, but if you have broadband, then this will speed up page loading. | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | I've found Firefox is significantly worse since doing this. I normally have half a dozen to loads of tabs open at any one time. Now, if I open 6 tabs at the same time e.g. new posts, all pages hang for about 30 seconds. Even had a few crashes. I've seen this but not tried it yet: _http://fasterfox.mozdev.org/ | ||
| Specialist Contributor Join Date: 02-06-2006 Location: Portugal
My System: Ouralis Evo3 80cm Dish/LNB 0.7dB Motor DISEqC1.2 G3ox via rs232 | Don't enable pipeline because there are lots of servers that don't suport it. The result will be pages that never end opening. Some good tricks can be found here _http://w*w.extremetech.com/article2/0,1697,1854234,00.asp | ||
| ..: :.. TigTex ..: :..![]() ![]() | |||
| Post Meister Join Date: 31-12-1999 Location: Berlin, Germany.
My System: 2xPace 430N, 1xNokia MM9800, 1xNokia 80cm Sat Dish, 1xGibertini 120cm, Big Fat Furry Puss | I am not claiming anything here - BUT - I swear that FF 3 Alpha 3 is fast - like faster than my Maxthon browser ;-(( Check it out/download here Apparently all the new stuff [at this alpha stage] is back of house - but try it anyways ;-)) | ||
| Have Fun, Moo. | |||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Thanks for that Mark, it does seem a little quicker, certainly with javascript viewers etc and the page loads are really snappy. | ||
| | #6 | ||
My System: Ouralis Evo3 80cm Dish/LNB 0.7dB Motor DISEqC1.2 G3ox via rs232 | That browser it's firefox 2 alpha 3. No firefox 3 a3.(at least, it's what I see) Seems like on firefox 2.0.1, pipeline can be safely enabled. It gives you an excelent speed improvement. Write about:config and search for pipeline. Change it from false to true. I also recomend you to change the network max conections to 48 and max connections per server to 28. I have a 4mb conection. Works great with me | ||
| | #7 | |||
| firefox, procedure, speed |
