Have a problem MPEG2 DVD conversionAll of us accessing this forum are using a computer, if you've got a problem, have or need information, then post here. | |
| Member Join Date: 31-01-2004
| Dear Friends I have a problem and need your help to solve if you can. I bought a Digital Satellite Card for my computer brand Vision Plus, and I record a film with it and it was great in quality but the problem is I tried to convert this copy from MPEG2 to DVD format “ Video-VTS” using program “ Neo Plus” to burn it after on a DVD Disk but I found out that after converting to Video-vts there is a picture without a sound, so I tried to use another program like “ Easy CD/DVD Creator V6.2 it works but I found out that after burning the film on a DVD disk the film are not complete the end titles are not there but there is a picture and sound I have installed all the codecs I found on the net so does any one faced the same problem or any body have a solution for it. Looking for your help ASAP. Best regards Mike | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | May be better to put this in the Computer section Mike, possibly more people there with DVD conversion skills. I will on this occasion copy ythis post to the computer section and leave this here. | ||
| Regular Contributor Join Date: 01-01-2000 Location: essex boy
| go to this place, they might give u some more help: www.dvdrhelp.com personally i use tmpgenc dvd author, it's great, i can use a variety of file format to burn into a dvd, available for 15 days trial from www.pegasys-inc.com . if you like it then $50 to pay or just yell loudly, someone will give you a keygen one question: have you tried to play the mpeg2 file by itself? does it have sound? | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Or try MOVIEMAKER it's free and quite versatile. Google finds it easily. | ||
| | #5 | ||
| Member Join Date: 21-06-2004
| have a look at my website should be all the info you need there http://wombles-dvds.tripod.com/womblesdvds/index.html still got to do a lot of work on the site but the main basics are there womble | ||
| conversion, dvd, mpeg2, problem |
Similar Threads | ||||
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Picture Problem !!! | Malteser | Cams and decoders General | 2 | 29-02-2004 09:00 PM |
| Have a problem with Vision Plus | mgharbawy | Satellite PC Card Receivers & Internet by Satellite | 1 | 15-02-2004 10:47 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
| Aston to Diseq poitioner problem | BazelAd | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 4 | 20-08-2003 07:21 PM |
