dragon cam with sky card
Discussion on specific encryption techniques not covered in the above forums
Old 27-01-2009   #1
My System: strong srt 4658x with dragon cam and a dreambox dm500s with CCcam, newcamd
hi guys, new to this ..im trying to get a sky card to work in a strong 4658x receiver with a dragon cam. when i go to the menue it says ' smartcard error (no ATR)..do i have to do something else or will it not work? the sky card is original...can anyone please help me
satelliteNOOB is offline   Reply With Quote
Old 27-01-2009   #2
My System: Humax foxsat pvr, amd64 x2, 250Gb hdd, ati 2600, 4Gb ddr2 ram
I use a dragon cam with a sky card in a Humax foxsat hdr. I've had no problems with it. The pred version is 3.62, which is not the latest.
Have you put the sky card in a sky box and left it for at least 2hours to make sure it's up to date? This can take longer so I'd put it in the sky box overnight and retry it later.
The cam doesn't pass through the keep alive signals to the card and so every 4 - 6 weeks it needs to go back in a sky box.
Hope that helps Dave.
prestwich1 is offline   Reply With Quote
Old 27-01-2009   #3
Usually the problem is that the card is inserted the wrong way round, it should be inserted with the chip facing upwards, into the Dragon Cam, facing downwards in your Digi box.
If this isn't the problem check that the Predator firmware, loaded on your Dragon Cam contains the correct CAID.
For premium channels to work, sports and films, you have to insert the sky box key into your Dragon Cam.
Mickha is offline   Reply With Quote
Old 15-05-2009   #4
thanks guys,
i had a talk with a mate over here (new zealand) and he rekons it might be that sky uses a different encryption to the uk sky? as my dragon cam is from the uk not nz? maybe thats the problem?
Old 15-05-2009   #5
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
If the Dragon menu doesn't include the conditional access system IDs (CAIDs) for Sky NZ, then you won't have any luck mate. No idea what they are in your part of the world unfortunately.
Llew is offline   Reply With Quote
Old 15-05-2009   #6
'What's On' Guru
dvmedia's Avatar
Real name: Chris
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M
Best newbie geek pit /age ratio 2005
Sky New Zealand uses exactly the same encryption (NDS Videoguard) as Sky Digital UK, Sky Italia, etc.
>> BBC Worlds' ultimate fan <<
>> Satellites are an expensive hobby that run away with you. I am living proof of this... <<
dvmedia is offline   Reply With Quote
Old 15-05-2009   #7
Llew's Avatar
Yes, same encryption, but different CAIDS. 096A and 0960 apparently.
Old 21-05-2009   #8
Llew, thanks but what are caids? can i reprogram my card? what do i need and where do i get the right files from?
so if programed right i could watch sky and foxtel (nds encryption) with original cards?
Old 21-05-2009   #9
Site administrator
Analoguesat's Avatar
No you cant reprogramme your card. Modern encryptions are totally secure and cards cannot be tinkered with.
Dragon cams - and various other modern cams allow existing subs cards to be read, but you get exactly whats autorised on the card, no more.
Analogue forever!
Old 23-05-2009   #10
sorry, i was not meaning to say reprogram my card but reprogram my cam? is that what i should do?
cam, card, dragon, sky
