cam info asked !Discussion on specific encryption techniques not covered in the above forums | |
| | #3 | |||
| Member Join Date: 06-01-2009 Location: the netherlands antillians
My System: kaon k270, conax | but you mean that if the channels are conax on you can,t get it ? with a cam ? or you mean payed movie channels . like that you order pay to preview ? ![]() ![]() what is a subscription card ? that is a orginal card or not ? | |||
| Super Moderator Join Date: 10-12-2004
![]() | Conax is an encryption standard so any channels using Conax are encrypted. Currently the MII+ card and the Diablo Cam open DigitAlb, 16E, and Canal Digital, 1W, packages, both of which are encrypted using Conax, but for how much longer is anyones guess. The Matrix Cam is an old multi cam and wont open either of these packages. A card is what you receive when you legally subscribe to a package, known as a subscription card or sometimes an original card. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | gerrit (05-02-2009) |
| | #5 | |||
| | #6 | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | As far as i'm aware it will still open the Nagra2 encrypted Digi TV on Thor @ 1w. Thats if you can find the files for it ![]() I'd hurry up though as this is going to be very short lived as Digi TV are in the middle of a card swapout which is expected to be finished very soon ![]() As soon as all their customers have their new cards the old knackered Nagra2 encryption will be switched off ![]() ![]() Nano | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| | #7 | ||
| Member Join Date: 03-09-2005 Location: neth.ant.
My System: pansat 2300/2500/2700 | For a CAM to work with a subscription card the CAM software must "know" some details of the subcription card provider. That is the reason why a specific cam will not work with all providers even if they use the same encryption system. As an example a Conax cam may work with some providers that use the Conax system, but it will not work with all Conax using providers. Also, a CAM will only open the channels that have authoristaion on the subscription or pre-paid card. | ||
| | #9 | |||
we have also nagravision here but that is already gone to the wind but now we have @onax .and i must say with these box from kaon k270 allot ah trouble. the signal every time gone but that,s wy i try to find other box that is good. greetings gerrit | |||
| | #10 | ||
My System: pansat 2300/2500/2700 | Gerrit can you explain what you mean with "the signal every time gone but that,s wy i try to find other box that is good." Are you having problems with signal strength? | ||
| asked, cam, info |
