[HELP] CONAX keys!
Discussion on specific encryption techniques not covered in the above forums
Old 03-11-2004   #1
Question [HELP] CONAX keys!
Hallo!,
Can anyone help me with conax keys for thor satellite.
At this moment i have
Keys deleted by Admin. Please read the rules, they are at the top of every section. !
on my receiver MVISION and i use emu
Thanks before.
tomodachi is offline   Reply With Quote
Old 03-11-2004   #2
Yes those are the old keys.... no keys should be posted >.<
Just look in the usual places, the conax key has been posted although I'm going to test it right now so dunno if it works yet.
h**p://www.sat-key.org/
Is a good start
Hope it's ok to put the link.
SatNewb is offline   Reply With Quote
Old 03-11-2004   #3
ciarank's Avatar
My System: FortecStar 5100 Ultra FortecStar LifeTime Classic
Is a good start
i have a the new key codes but the are in lowercase.
does the fortec star allow you to enter codes in lowercase? or should i ienter it all in uppercase as i normally do
..........hello?
ciarank is offline   Reply With Quote
Old 03-11-2004   #4
I'm not sure mate but I can confirm the new key works on the Dreambox all in lowercase.
I noticed that too and wasn't sure if it would make a difference if the letters are in upper or lowercase but I just copied and pasted the keys as they were and it worked, all in lowercase.
I would say just put them all in as lowercase and see if it works. If it doesn't and you put them in as capitals and it works then you'll know what to do for future reference
The keys do work though so good luck
EDIT: It technically shouldn't make a difference if they are capitals or not because the keys are hexadecimal. It only goes 0-9 and A-F and it's only when writing that we use capitals or lowercase letters. AFAIK hexadecimal lettering should work either way
Old 03-11-2004   #5
ciarank's Avatar
thx for the info - will try to enter code tonight.
..........hello?
Old 03-11-2004   #6
Irish Mod
Razor's Avatar
New Keys ( key 21 ) do work.
I got CNX back last night...With a new TBM file from DUDEZ.
Don't mind my spelling
Razor is offline   Reply With Quote
Old 04-11-2004   #7
ciarank's Avatar
working for me also. oh joy!
..........hello?
conax, keys
Similar Threads
Transponder update October 2007 Satdude Transponders & channels 666 25-10-2007 11:44 PM
Cable Conax Keys (in Finland) Quubee Keys and Key editing 2 30-07-2007 07:46 PM
Conax plans to set up unit to support CAS in India net1 Indian Subcontinent General Section 6 17-08-2006 05:52 PM
Conax key's? HighAce Keys and Key editing 36 02-12-2005 06:24 AM
Conax + tita advice, please stratosg Conax, Cryptoworks, Nagravision, NDS and Others 1 11-02-2004 10:57 AM
