Conax 4.00 & Interface Help Required | |
| Member Join Date: 12-02-2003 Location: Yorkshire
Conax 4.00 & Interface Help Required I've just brought a Conax EuroCAM 4.00 and interface from my local shop. His software will only work with Conax 3.03, but not with 4.00, and he's only selling the Conax 4.00 cam and has not had time to update his software. So my question is:- Does anyone have or know where I can get the software for the Conax 4.00 set-up for viewing THOR. Thanks in advance m8s Paul | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I presume that you mean emulation software, you should be able do download from several of the sites listed in Nobbly's big links forum.
__________________ | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Third forum down from the top of the main index page Paul. you should be able to get it at Phill's, Toecutters, Satdudez and TonyDoe's.
Similar Threads | ||||
| Transponder update October 2007 | Satdude | Transponders & channels | 666 | 25-10-2007 11:44 PM |
| Conax plans to set up unit to support CAS in India | net1 | Indian Subcontinent General Section | 6 | 17-08-2006 05:52 PM |
| Conax + tita advice, please | stratosg | Conax, Cryptoworks, Nagravision, NDS and Others | 1 | 11-02-2004 10:57 AM |
| Conax 4.00 e and nagra... | tunte | Conax, Cryptoworks, Nagravision, NDS and Others | 2 | 25-01-2004 12:29 PM |
| Pleas Help Me SEASON INTERFACE 2 | farrukh | Cards & Programmers General | 1 | 03-08-2003 12:31 PM |
