Set-top box struck
Discussion of Dish and TataSky only
Old 03-12-2007   #26
Member Satellites.co.uk
anishks's Avatar
My System: NSS 6 (Dish T.V - K.U Band), Insat 4B (DDDirect Plus, Sun Direct - K.U Band) ,Insat 2E (C Band) & Insat 4A ( C- Band) - PC AMD Athalon 64*2 , 120 GB HD, 1 GB Ram. OS XP & Obuntu.
Originally Posted by member91040 View Post
Sorry Bro NO IDEA, May some one will reply you. But what is the problem.
Hi, i fix the issue, it's my mistake not software, its a hardware issue.
and rectified it.
anishks is offline   Reply With Quote
Old 03-12-2007   #27
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
What was the actual problem bro. In hardware.
member91040 is offline   Reply With Quote
Old 04-12-2007   #28
anishks's Avatar
Yes. Power supply Issue. Power Filter (Electrolytic Capacitor Leakage).
Thanks.
Old 04-12-2007   #29
My System: Inast 4b,insat 2e/3b/4a,hotbird 6/7/8
try to put off the power supply to set of box and put it on after 5 minutes and try
gurus05 is offline   Reply With Quote
Old 05-12-2007   #30
anishks's Avatar
Thanks gurus05, i fix the issue. just check my post
box, settop, struck
