Set-top box struckDiscussion of Dish and TataSky only | |
| Member Join Date: 14-03-2007 Location: India
My System: VC 01500986794 Dish TV |
Please help me short out the problem of SET TOP BOX STRUCK. after switch the set top box, automatically struck. can;t see channels, menu ....plase help receiver name : Supercomm fta | ||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | no menu noting under display , Just reset if menu active, If not check weather keys are pressed . | ||
My System: VC 01500986794 Dish TV | Dear friend, Nothing keys not working either remote / front panel of receiver. Full Struck condition. after switched on, Just display "001" channel no only. what i will do ?please help me. how i can i reinstall software? if u know plz let me know. vishwa | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | What is the Model number bro , Let me see. | ||
| | #5 | ||
My System: VC 01500986794 Dish TV | Dear Friend, In that Receiver, there is no model number, I have checked fully,..... i can't find out model name. Just only Brand Name : SUPERCOMM. What i will do Boss? How i can re-install software? which loader i have to use for this? Do u have any loader? and loader & bin file, settings file.. pleasee help me out....if u have plz send to me v+i+s+h+w+a+2+3+@+g+m+a+i+l+.+c+o+m. Please..... | ||
| | #6 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Vish its critical to understand what kind of receiver you have...! Its better you take few snaps and paste it here, Soo every body can check it and may get help from any side, If it is local china made any kind of chinise firmware can match on that.Until than you cannot do any thing. Or else u will loss your Receiver. | ||
| | #7 | ||
My System: VC 01500986794 Dish TV | Dear Frd, If i use some other firmware, what will happned? receiver will damage??? ..ohh god.. plz tell me.. then I have Indian Dish TV zenega cd1004s model.. with latest software..its automatically updated.. there is no option for sat/tp edit. what i will do? can u have Zenega cd 1004s..old firmware??...or initial factory original bin file...plzz tell me... how can i get Handan download manager?.... | ||
| | #8 | ||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| Did you try to unplug the box from the mains and wait few minutes and then plug it again ? | ||
| | #9 | ||
My System: VC 01500986794 Dish TV | Friend, I have done same like that....whole day. nothing happned..same condition. i can't find out model name. just i attach the image of receiver ,Brand name Supercomm. ..plzzzz give the solution...how to i solve the problem??? plzzzz IMAGE I HAVE ATTACHED....... | ||
| | #10 | ||
My System: VC 01500986794 Dish TV | | ||
| | #11 | |||
| If I were you, I would take it to the shop where you bought it and ask them for their advice or send it for repair but ask for an estimate first. Good luck. | |||
| | #12 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Try to search Older threads You will find answers for Dish TV zenega cd1004s model. | ||
| | #13 | ||
My System: VC 01500986794 Dish TV | No boss i can't get Zenaga cd1004s bin file..okey please tell how to solve the SUPERCOMM receiver problem? i have send receiver image....plz advise me.... what is procedure for reinstall..? which software's i have to use? what is the process? i am new for this field... plzz man,, | ||
| | #14 | ||
| Member Join Date: 06-07-2006 Location: Karwar
My System: IBM Laptop, Humax with 90 cm dish |
Hi Vishwa Perfectly understand your concern/worry. Dont panic. The internet is a vast library on which you will stumple upon with your required piece. Rgds Vimal | ||
| | #16 | |||
| It might also be a hardware problem. See post #11 BTW the picture you attached isn't helpful, even the logo is not shown. Try to make few more with details and zoom. Also from backside to see the connectors and the bottom side. Can you give us a little bit more information like: When did you get the STB How did you get it Was there any information in the box container like a manual or troubleshooting info. If you still have the box container, look for any more information like made in which country. The name and address of the distributor. Without your full cooperation and feedback, I doubt if anybody can help you. | |||
| | #17 | ||
My System: VC 01500986794 Dish TV | Dear friend, No hardware problem. bcoz its happening when i am doing the auto search & trasnsponder edit time...suddenly its gone like struck condition. . Brand Name : Supercomm. no manual for that receiver. no manufacturer name... Only just display brand name : Supercomm. backside is in Rs-232 port available. please help me. model looks like image what i attached | ||
| | #18 | |||
Do I understand that you can still work with the receiver to do auto search or it is stuck all the time ? If you can still make it function, then check if there is an about or help menu and it might show you some information about the software. If it does, post full details even an image. | |||
| | #19 | ||
My System: VC 01500986794 Dish TV | Dear friend, Nothing work. full hang condition. after switched on the receiver just display 001 only. nothing work even front panel, remote... display seems "----" thats all. this problems started on last week, when i am auto searching / sat edit time. i have switched off / on..nothing happned,. still stuck condition.... means hang... | ||
| | #20 | |||
The only other possibility that I can think of is that you might get it out of the hang condition by using telnet to negotiate with it. Need a null modem cable between PC and RS-232 connector at the back. I am not an expert on telnet, so I will leave it to the experts. Make a new thread with the heading "Telnet communication with STB" so that members with telnet experience might see it and reply. Good Luck. | |||
| | #21 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Let me try to arrange the Bin file for you, But do it yourself...! May be risky. Own Luck. Regarding your stuck problem, No way to watch pic or logos cant able to find this kind of receiver any were from my side, May some one help you out. | ||
| | #22 | ||
My System: VC 01500986794 Dish TV | Dear frnd, if u have any other loader, bin file, any other firmware..plz send to me. its urgent. what is telnet? what is null modem cable? how connect with stb?... plzz utgent | ||
| | #23 | |||
| Member Satellites.co.uk Join Date: 19-02-2007 Location: Kerala
My System: NSS 6 (Dish T.V - K.U Band), Insat 4B (DDDirect Plus, Sun Direct - K.U Band) ,Insat 2E (C Band) & Insat 4A ( C- Band) - PC AMD Athalon 64*2 , 120 GB HD, 1 GB Ram. OS XP & Obuntu. | I need the same, one of customer using the Arraycom reciever and Now it has some problem. hardware is ok. please help. | |||
| | #24 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Sorry Bro NO IDEA, May some one will reply you. But what is the problem. | ||
| | #25 | ||
My System: NSS 6 (Dish T.V - K.U Band), Insat 4B (DDDirect Plus, Sun Direct - K.U Band) ,Insat 2E (C Band) & Insat 4A ( C- Band) - PC AMD Athalon 64*2 , 120 GB HD, 1 GB Ram. OS XP & Obuntu. | | ||
| box, settop, struck |
