procedure to add tps manually in Dish tvDiscussion of Dish and TataSky only | |
| ASBO Club Member - Persona non grata Join Date: 06-03-2007 Location: south india
My System: dishtv |
[dishtv] Press Menu -> Settings -> Select STB info -> Press OK -> Press Red button on remote -> Press OK -> Now Press 7531 code on your Remote -> Set the correct downlink frequency of your new Ku-band transponder ( i.e home transponder of your network) -> Press Red button to save the parameters ->Now Check the recently added TP's signal strength with correct downlink parameters -> if signal is fine, now exit from menu by pressing yellow button on your remote -> Now your STB will ask you to start Scaning new TP by just pressing OK button on your remote. d.prabakaran | ||
| | #2 | |||
| Member Join Date: 26-11-2006 Location: India
My System: DishTv DTH Zenega 1004S |
how to add transponder.... here u can only edit the home transponder... is there any way in which i can add transponder and move my dish to capture othere sat | |||
| Member Join Date: 08-03-2007 Location: India
My System: DISH TV DTH, ZENEGA STB, P-4, | Thanks for the information.....Also explain the benefit that we can get by editing the home TP....Can we get any new channels by following the procedure provided by you... | ||
| | #5 | ||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | | ||
| | #6 | ||
| Member Join Date: 13-09-2006 Location: visakhapatnam
My System: dishtv my set top box is zenega CD-1004iS | wat tps can we add on nss6 plat form so that we can recive other channels\ >>>>>After Updating There is no way to add. i mean to ask wat value we can enter in the editing process so that the dish can recieve! hav any one tried it and got successsfull? | ||
| | #7 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Bro what do u mean by recive other channels, It means other sats, Before updating its ok, After updating No way. | ||
| | #8 | ||
| Accustomed Geek Join Date: 15-12-2005 Location: Mangalore,Karnataka,India
My System: Satellite: Dish Tv India With Zenega and Beetel 96 SD amp receiver. 60 cms( Dish TV) and 90 cms(MCBS) dishes. My Computer: Intel Core Duo 3.4GHz, 512MB DDR2 ram,FC6 And Win XP-SP2 | Hi, The info about editing the TP is a very useful feature satdxer has provided us, i believe, Many thanks to him. One will not be able to tune any channels, but it can be used to track other satellites and TP's. I have both zenega and beetel 96 sd recievers. I was able to track ST1, edusat and ABS1 with the sound signal meter of zenega after editing the Home transponder TP. Since beetel does not have that feature and its impossible for me to carry the TV to the roof top. Once the signel was locked i scanned the TP with my Beetel to receive the FTA channels. I was greatly benefitted with the above info. Regards, Hsenet | ||
| | #9 | |||
My System: DISH TV DTH, ZENEGA STB, P-4, | Hi hsenet, Are you using the DISH TV's Zenega hardware? and were u able to edit the TP?
| | #10 | ||
My System: Satellite: Dish Tv India With Zenega and Beetel 96 SD amp receiver. 60 cms( Dish TV) and 90 cms(MCBS) dishes. My Computer: Intel Core Duo 3.4GHz, 512MB DDR2 ram,FC6 And Win XP-SP2 | Hi Allen, Yes, I am using Dish Tv's Zenega, with the updated software, and i can edit the home transponder. But I cannot scan the edited TP to tune any channels. I have an additional Beetel receiver, Once i get a signel, i remove the cable and fix it to my beetel and scan for the channels. This is a novel method, as for me, to track other sats using the sound meter facility in zenega. Hope this helps. Regards Hsenet | ||
| | #11 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Its better we use free to view receivers to catch other birds. | ||
| | #12 | ||
My System: Satellite: Dish Tv India With Zenega and Beetel 96 SD amp receiver. 60 cms( Dish TV) and 90 cms(MCBS) dishes. My Computer: Intel Core Duo 3.4GHz, 512MB DDR2 ram,FC6 And Win XP-SP2 | But they donot have sound tracking feature that Zenega has! | ||
| | #13 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Some Or Some how miss the features, Specific may miss few in others. | ||
| | #14 | |||
| Member Join Date: 03-08-2006 Location: INDIA, HOSUR - TAMIL NADU
My System: DISH TV |
I tried NSS6 satellite, 95 Deg. east, 11091 H 29500, this is for CGNTV , free to air. | |||
| | #15 | |||
Thanks for the information, even I am able to edit the Tp. But once, I have edited it I am not able to scan the channels. it throws up some error. So as I understand, you connect a different receiver. Could you elaborate more on "Sound Meter" facilty of Zenega STB? | |||
| | #16 | |||
What I mean when i said "Sound Meter" (i couldn't get another word for it!!), is that the stb makes one kind of a sound through your TV Speakers when there is no signal, as the signal increases it will increase the pitch, that way you need not a visual indication that you are getting the signal while tuning your dish antenna. That way you can tune to any satellite just by editing the home TP and increasing ur sound volume and go to your roof top, you need not take the TV, just by following the sound, you can know while tracking a sat, whether you have got a signal or not. After u get a signel, detach the cable from your Zenega, and attach it to any FTA STB, and scan for the channels on that TP. This makes tracking satellites easier. Donot forget to restore your zenega to the old Home TP. I hope this helps. Hsenet | |||
| | #17 | ||
| Member Join Date: 26-01-2005 Location: AHMEDABAD GUJRAT INDIA
My System: ZENAGA STB ALL MODELS. KAON ALL MODELS AVAILBLE FOR DISH TV. |
I Tired It On My Zenega But I Was Not Able To Scan . Now We Should Try To Modify The Software Uysing Some Loaders Or Stb To Stb Way . Because On 1st June The Dd Direct Plus Will Change The Satellite And Then All The Dish Tv Viewers Will Be In Middle To Trouble. Please Find Any Loader And Software For Zenega Receivers And Inform I Am Searching The Same But I Am Not Successfulll In That , Look After The Same, Regards, \ | ||
| | #18 | |||
| Member Join Date: 19-03-2007 Location: north east india
My System: I HAVE INSTALL DISH TV CONNECTION WITH DD DIRECT+ AND HAVE COMPUTER |
| | #19 | ||
My System: dishtv my set top box is zenega CD-1004iS | I tried to add new tp as per above procedure, but not received any chennel. I tried NSS6 satellite, 95 Deg. east, 11091 H 29500, this is for CGNTV , free to air.///////////////////////////////////////// its not working bro there must bre some way that we can break the lock of zenega | ||
| | #20 | |||
| | #22 | |||
| Member Join Date: 03-06-2007 Location: colombo
My System: ALL SATELLITE |
2 new satellite Thanks for the information, even I am able to edit the Tp. But once, I have edited it dishtv packege gone new 2 satellite scan the channels. i'm chek two satellite tatasky, intelsat 12 i's ok no dishtv channels | |||
| | #23 | ||
| Member Join Date: 30-07-2007 Location: Aurangabad, Maharashtra, India
My System: KAON KSC-i260 MCO, DISH TV DISH, TONYTONE STB, Ku Band LNB ... P-III 550 Mhz, 88 GB HDD, 194 MB Ram, Bluetooth Dongle, | Recently I have bought a new dish tv,,, so joined this forum,,, now from the forum I came to know that to get almost all free channels from diff satellites , we need a moving dish and a normal stb, not a dish stb,,,,Now let us take my case,, I am having dish tv of 60 cms, KAON KSC260 , and it supports diseq something like tht for motorised dish,, now whats the correct procedure,, should i get another stb ,, and attach a motor to my existing dish antenna,,, and from the same lnb,, i will connect to two stb,, one dish tv stb another normal stb in which i can add satellites,.. But while watching tv,, i would need to use two remotes , of dish tv stb and normal stb,,, and apart from main components i would also needs some wires, joiners ,splitters etc etc,, so as to receive the channels from 2 stbs into one tv with one dish and one lnb... is it possible pls advise and tell some procedure to complete it. also give in detail abt components required.... THANKS AND REGARDS,,, please reply to my gmail account | ||
| add, dish, manually, procedure, tps |
