connecting Monoblock and single LNBInformation exchange on digital satellite systems other than Sky | |
| Specialist Contributor Join Date: 28-05-2003 Location: Florence Italy
I am going to set up 16deg /e LNB to receive Digialb,to do this is a bit confusing,as I have 13/19 deg monoblock with disq switch, for Hotbird and Astra. Is it possible to install a 2x1 disq switch in line,or should i install 3 separate LNB,s with a 3x1 disq switch | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | As long as you use a committed switch, which most of the cheaper ones are and can enter two stage commands in your receiver, then it should work. | ||
| The Following User Says Thank You to rolfw For This Useful Post: | dave branson (06-08-2007) |
| connecting, lnb, monoblock, single |
