Horrible video quality NoK 9500+DVB Help | |
| Guest
Posts: n/a
I have just bought a 9500 with DVB200 V 1826 installed. The picture on any channel is awful, like a pop video when they go into negative effects with colour, or a jpeg that is too compressed. LNB works fine on my analogue Receiver and it is a Universal ( cambridge ) 9500 will scan astore channels etc. OK Have carried out a reset by holding up down buttons and bringing out of standby as suggested by someone on another forum, but no different Any ideas? Thanks | ||
| Specialist Contributor Join Date: 01-01-2000 Location: uk
Hello B7 How are you connected to to TV. [RF or Scart] It could be that you are set up for RGB, which can look a bit odd if the TV isn't re-adjusted for it. [Not all can be] Check the video output settings on the Receiver and see if is set to RGB, and if so try changing it. Just a thought!! Good luck W Hole | ||
| Guest
Posts: n/a
I have the 9500 connected direct to TV via a fully wired scart connection which auto switches to the 9500 ouput when I switch on the receiver. Have also tried a small colour portable with scart and the effect is similar. Swapped the scart as well....Grrrrr ..... frustrating ![]() Thanks for reply. | ||
Similar Threads | ||||
| Transponder update October 2007 | Satdude | Transponders & channels | 666 | 25-10-2007 11:44 PM |
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| SKy+ installed but now I have a video problem? | rapterman | Sky+ and PVR Systems | 3 | 03-02-2004 08:42 PM |
| Best video qualtity, Skystar 1 or 2? | mtiller | Satellite PC Card Systems & Internet by Satellite | 13 | 03-12-2003 09:30 PM |
| DVB Video Capture? | homerjay | Satellite PC Card Systems & Internet by Satellite | 0 | 28-11-2003 04:14 PM |
